Old 09-05-2014, 09:25 AM   #1
IchLiebeBier's Avatar
Awning Application Chart ???
All,
Does anyone know of an awning application chart, or do the awning companies rely solely on customer measurements?
I want to price check a slide out awning and install, but the dealer said they'd have to measure it and figure out the size of the awning before they'd give me a price. I thought if I could get the proper size ahead of time, maybe I could get a price before I hauled it down there.
FWIW, it's a 2015 Wildwood 26TBSS.
Thanks.
IchLiebeBier is online now   Reply With Quote
Old 09-05-2014, 09:30 AM   #2
Measure from the front edge of the slide to the back edge of the slide and that's the length you need.
Old 09-05-2014, 11:01 AM   #3
I thought I read to add 6", then round up to the next whole even number, or something weird like that.
Old 09-05-2014, 11:19 AM   #4
Go to this site and look at the diagram on determining size. Dometic 86096 Elite SlideTopper FRTA Awning Vinyl Fabric with Metal Weathershield Camper Trailer RV
Old 09-05-2014, 12:23 PM   #5
Witch Doctor's Avatar
What they do is send the piece bigger then what you measured. Then they cut it with scissors to the exact size that you need I gave them my measurements as stated above. Both came and had to be cut to size. I just I had 2 replaced last week. If a dealer is doing it, they have a big roll and cut it off as needed. The problem is when you get it from them and not the dealer they fold it up and it is hell tiring to get the crinkles out. This per the head man at the rally a MR. AL McQuire who looked at mine, and told me what to expect. They sent the ones I measured about 4" longer then needed. That's after they re measured mine themselves one at 117" and one at 158" if I remember right. It's easier to cut them. If it's to short someone will eat it and it will not be them....My point is to add the 6" that you read somewhere it's probably correct....Good luck. save the old ones they make a great picnic table cover or a ground cover if you have to crawl under your trailer for any reason.
Coachmen M/H
Concord
2018 / 300 DSC
Old 09-05-2014, 12:52 PM   #6
If you read the OP's original post, he is trying to buy the complete unit, not just the replacement material.
Old 09-05-2014, 01:29 PM   #7
Your correct but I just looked up my size 158" they recommend 168" awning, that would be 5" over hang on each side. I personally would not want a topper hanging over 5" on each side. OP should just call dometic and give them the edge to edge measurement that it has to cover.
Coachmen M/H
Concord
2018 / 300 DSC
awning, cat
