Old 09-19-2019, 05:06 PM   #1
Awning arm repair- 07 FR Wildcat 5th Wheel
Had storm damage and have all repaired EXCEPT the left awning arm. I just bought this and docs are few. Need help with part number or something that I can give vendor for replacement. Is 73 inch Dometic outer arm and slotted inside rail. DryerRV and Dometic want part number. All I can find on good arm is AE Dometic sticker.
ANY HELP IS APPRECIATED!!
Tony
Tzehia is offline   Reply With Quote
Old 09-19-2019, 08:36 PM   #2
SeaDog's Avatar
Have you looked on the inside of the main rail arm? That is where you may find a part number on a sticker.
Retired Navy
Jake my sidekick (yellow Lab)
2016 Flagstaff 26 FKWS
Old 09-20-2019, 06:20 AM   #3
Thanks Seadog
Will do. Be a bit tricky as the canopy is zip tied on that side!
Old 09-20-2019, 06:38 AM   #4
SeaDog's Avatar
I just saw this is your first post so welcome to the forum its a great place to get your questions answered.
Retired Navy
Old 09-21-2019, 06:40 PM   #5
Model Number
Tony
Tony if you can get the serial number off the roller tube Dometic can track the shipment and find the original hardware model number. I assume it is not electric. 73 inch arm is standard not short should be model 8500 series awning.
Short arm would be 61 to 63 inch. Call Dometic and ask for Elaine. 800 544 4881.
almcguire is offline   Reply With Quote
5th wheel, awning, cat, repair, wheel, wildcat
