Old 07-15-2014, 09:47 AM   #11
Where should we go next!
Offagain's Avatar
I really try not to put mine away wet. Any sign of rain in the forecast,it gets rolled up. Also roll up the night before we are heading home. This way there is no dew on it in the morning when we start closing down.
Either way, a little"TileX" and your good to go. Not a big job at all. If you keep up with it, you won't even have to scrub. A little spray, roll it up for a bit, hose it off and let it dry.
Ford F-150 4X4 Supercrew Ecoboost
Surveyor SV291
Equalizer 4-point 10K lbs.
Offagain is offline   Reply With Quote
Old 07-16-2014, 06:39 PM   #12
Chillbilly's Avatar
So much for LAs Totally Awesome. Found some at the local Family Dollar. Sprayed it on, rolled it up, and waited 30 minutes. Did nothing. Repeated the entire process. Again, nothing. I emailed the manufacturer, who has other products, for advice or recommendations. No answer yet. Tomorrow I will try Tilex.
Chillbilly
2013 Rockwood Signature Ultra Lite 8244WS
2015 Ford F250 Quad Cab w/6.2 Engine
Chillbilly is offline   Reply With Quote
Old 07-16-2014, 06:46 PM   #13
heavynlori's Avatar
We mix bleach and simple green with water in one of those pump garden sprayers - wet awning with water and spray liberally - roll it shut and we leave it until we are done washing the camper - then open it and hose it off - there may be a few minor spots that might need a light scrub with the brush but usually not...easy peasy 😉
heavynlori is offline   Reply With Quote
Old 07-17-2014, 07:49 PM   #14
Offagain's Avatar
Bleach is really the key component in all of this. If it is in whatever you're using, it should come clean.
Surveyor SV291
Old 07-17-2014, 08:25 PM   #15
Did you then use a soft brush to lossen up the dirt, or whatever. What procedure did you employ along with coating the vinyl with Awesome for 30 minutes.
Old 07-17-2014, 08:27 PM   #16
Kris10May's Avatar
Yes...we used a brush to really scrub it down. It isn't 100% clean but oh so much better than it was.
Kris10May is offline   Reply With Quote
Old 07-17-2014, 08:57 PM   #17
If you read that post it was meant to quiz chillybilly.
Old 07-17-2014, 10:42 PM   #18
Hmmm... I use my awning to stand outside when it's raining and I assume many others do. Seems like you're losing one of the bigger reasons to have one in the first place.
2011 F150 SuperCrew 5.0 4x4
2012 Flagstaff 27BESS
pappcam is offline   Reply With Quote
Old 07-17-2014, 11:02 PM   #19
Offagain's Avatar
[QUOTE=pappcam;660573]Hmmm... I use my awning to stand outside when it's raining and I assume many others do. Seems like you're losing one of the bigger reasons to have one in the first place.[/
I do leave it open in if it's not forecast to rain too bad (And pitched to one side for sure) and I'm going to be there for nicer weather. If I see rain in the forecast and no real sign of it drying out. I'll put it away as well as our mat.
Surveyor SV291
Old 07-17-2014, 11:07 PM   #20
Offagain's Avatar
When I first started out camping and I had a pop up. I couldn't figure out why everyone pitched their awnings to one side. I figured the pitch outward was enough. Big mistake! Rained overnight and woke up to an inverted giant zit! Luckily it didn't ruin the awning. My wife and I pushed up on it and got all the water off. Lesson learned.
Surveyor SV291
awning
