Old 04-08-2013, 07:48 AM   #1
Rhino1's Avatar
Awning closes only half way?
I'm in the middle of packing up camp and the awning will only close half way any ideas what's up ? I have a power awning .
2014 Silverado Crew Cab 1500 5.3ltr
Rhino1 is offline   Reply With Quote
Old 04-08-2013, 07:53 AM   #2
Need just a little more information.
Old 04-08-2013, 08:00 AM   #3
Rhino1's Avatar
I start to retract it and it starts to roll in until it reaches the halfway point ish and it makes a grinding type noise then stops but will extend back out to fully open. I don't know the brand of the awning .
Old 04-08-2013, 08:06 AM   #4
Is the material rolling up straight or to one side? If it is rolling to one side, it needs to be centered on the roller. When it stops, check that the arms are not in a bind.
Old 04-08-2013, 08:07 AM   #5
Herk7769's Avatar
My money is that the awning material has slid to one side due to wind flapping.
As it retracts, the awning arms are binding.
Extend the awning and using a ladder "flap" the awning material while pulling on it to slide the awning material back to line up with the "dirt line" on the roller.
When it rolls up perfectly straight (may take several tries), I pop riveted the awning material to the roller at each end to prevent it from happening again.
HAM CALLSIGN - KC3FFW
Old 04-08-2013, 08:07 AM   #6
SYE
SYE's Avatar
By chance is one of the support arms locked down with the thumb screws??
Scott & Vicki
2018 Silverado 3500HD Dually 6.6L Duramax/Allison
2018 Columbus 366RL 1492 Edition
Camped 2012 19, 2013 110, 2014 129, 2015 97
2016 93, 2017 79, 12 Nights Camped 2018 57 nights reserved
SYE is offline   Reply With Quote
Old 04-08-2013, 08:08 AM   #7
Maybe a dumb question on my part, but are the knobs loose on the support arms so they will slide together as the awning rolls up?
If these are tight it may prevent the arms from closing up, otherwise I'm not sure why it only closes halfway.
2011 SunSeeker 3170DS
hunt247 is offline   Reply With Quote
Old 04-08-2013, 08:28 AM   #8
SYE
SYE's Avatar
Anoither thing to check is, did someone put ma campfire stice in the awning channel, My DW has done this to me a few times as well. My guess is what Herk said, as this happened on my last 5er Manual Awning, it would not slose because it had moved on the roll.
Scott & Vicki
Old 04-08-2013, 08:54 AM   #9
Twigs or walking sticks layed in the upper channels can slide toward the hinge point while folding up. Youroo!!
Old 04-08-2013, 09:36 AM   #10
Rhino1's Avatar
I got it to close finally but it did so very slowly. Still not sure the issue will investigate further once were home and I have a ladder and more tools .
