Old 10-02-2013, 04:45 PM   #11
Warrior's Avatar
Originally Posted by OldCoot View Post
I made hinged covers for just the ends that work great for keeping the water out of the ends of the awning.
Can you deploy and retract the awning with the covers in place? Could the full length covers be used in conjunction with your covers?
Wayne & June Bowers Camp Mutts Bo & Baby
2011 F250 Lariat 4X4 SCSB 6.7 Power Stroke
50 Gallon Titan Fuel Tank
2011 Flagstaff 8528RLWS 5th Wheel
Reese Sidewinder Hitch 2002 Road Star Warrior
SouthWest Florida FROG
Warrior is offline   Reply With Quote
Old 10-02-2013, 04:47 PM   #12
DAISY BOYKIN's Avatar
You know who---------------
You know who come up with the ideas he has? TOWTA, that is who. OC is just the labor!
Sid, Lois & HRH MISSY Terrible 2s SHIH TZU
2011 ROCKWOOD 8285 WS
2014 F-250 KING RANCH PS/SD/6R140/BFT
DAYS CAMPED 2018 21 DAYS
DAISY BOYKIN is offline   Reply With Quote
Old 10-02-2013, 05:26 PM   #13
Could, but you would still have to get a ladder out and take off and re-install the other covers.
Old 10-02-2013, 05:29 PM   #14
Originally Posted by grayfox View Post
Nice job as usual , Coot.
Thanks Fox.
Old 10-02-2013, 05:51 PM   #15
Platokidd's Avatar
Modern Marvels of the RV
Brilliant. Just another great idea, fab, and install
2014 LaCrosse 323RST-TE-C
2009 Chevy 2500HD Z71
nights of camping
2017-67 / 16-92 / 15-73 / 14-60 / 13-33
Seasonal
Platokidd is online now   Reply With Quote
Old 10-02-2013, 06:40 PM   #16
DDC
DDC's Avatar
O C do you have a parts list? This is a must have, I hate having to clean the awning even when it hasn't moved.
Cedar Creek Silverback 33IK
Donald&Casey cairn terrier
DDC is offline   Reply With Quote
Old 10-02-2013, 06:59 PM   #17
I went to Lowes and bought a 24" length of 6" pvc pipe and an end cover and ordered a 4' length of 1" stainless piano hinge on ebay. Cut a 14" long pc of the 6" pvc and then split it to give me 2 pcs approx. 8" wide measured around the curve, rounded the edges with a belt sander so it wouldn't mark the awning material. Painted it white with a paint for plastic and cut the end cap to fit on one end. Pop riveted (3/16" large head) (removed the mandrel that breaks off in the rivet and hammered the hollow stub flat on the rivet) a 14" of the hinge to one edge, drilled 3 holes in the loose side of the hinge and used ss screws to attach to the awning rail. Installed hinge right over the vinyl filler strip. Filled the holes drilled in the camper side with silicone caulk and installed the screws. I did some modifying of the front to facilitate the lock I have. If you don't have the lock, there is no need to modify the motor end. You might have to heat and flatten the pvc slightly to make sure it doesn't 'catch' on the awning when deploying. Heat before painting.
Old 10-02-2013, 08:09 PM   #18
DDC
DDC's Avatar
Thanks a million I really appreciate you sharing this, hope others will also.
awning, cover
