Old 06-26-2014, 09:44 AM   #11
Originally Posted by Herk7769 View Post
You are OVER extending your awning.
In a properly extended awning, the material needs 1/4 wrap on top to stiffen the material and prevent pooling. The "flap" should hang straight down and the flap slot should face out (away from the camper). This will mean the accessory slot will face the camper and not face down...
Only problem is if you hang a sunscreen in the groove, the awning will automatically roll to form the valley as the top material groove and the sunscreen groove are not 180 degrees apart. If the tube is tilted, the groove/valley is not a problem anyway. Been doing it for years with no problem.
Old 06-26-2014, 03:17 PM   #12
Herk7769's Avatar
With the awning poles, the location of the groove does not seem to matter.
HAM CALLSIGN - KC3FFW
Old 06-27-2014, 02:36 PM   #13
tmhyer's Avatar
Why is your awning extended in the rain anyway? My understanding is to only extend it when you are using it, and it is only to shade you from the sun.
tmhyer is offline   Reply With Quote
Old 06-27-2014, 02:55 PM   #14
Ret E-9 Anchor-clanker
donanddona's Avatar
My Yorkies do like the awning out to do their business.
donanddona is offline   Reply With Quote
Old 06-27-2014, 03:47 PM   #15
mlong's Avatar
Why would you retract your awning just for rain. Unless it is windy I like to keep it out
2012 Chevy Silverado Crew Cab Short bed 5.3L v8
2014 Prime Time Manufacturing Avenger ATI 27BBS
mlong is offline   Reply With Quote
Old 06-27-2014, 03:54 PM   #16
With the awning poles, I set the tilt, tie it down and we never take the awning in unless they are predicting 25+mph winds.
Old 07-21-2014, 01:46 PM   #17
2016 Avenger 26BH
self dumping
Hi our 195Bh awning is self-dumping. But i do raise the front of the trailer a bit while it is raining so the awning dumps at the back not near the door at the front. I did notice my awning frame has an hinge point that is normally straight when the awning is out. I have found that during the rain that if i pull down on that hinge it loosens the awning on that end and cause it to dump more often with less water/weight buildup. just be sure to straighten it out before storing the awning.
Cleon is offline   Reply With Quote
Old 07-21-2014, 01:56 PM   #18
TURBS's Avatar
Its Easier to just tilt the awning and lock the arms.
"sabre owners united!"
turbs
Old 07-21-2014, 02:13 PM   #19
2016 Avenger 26BH
true but our awning is not tilt adjustable like the older "carefree" and "domenic" ones. simply "unlock" and pull out. there are no sliding adjustable arms on the ends.
Old 07-21-2014, 02:27 PM   #20
TURBS's Avatar
Is it an electric unit?
turbs
awning, drain, water
