Old 04-30-2019, 08:01 AM   #1
Awning end cap for e pro 14 fk
Hello!
I stupidly opened the trailer door and then opened the awning which hit the door which was not completely opened. Result: The right hand plastic end cap which goes over rolled up awning was knocked off and broken. I called Forest River and got build list for part info then called Dometic for part availability. Dometic said that part is not available and awning is discontinued.(This is a 2018/2019 trailer!)They said I may be able to find complete roller with end caps at a RV suppler. Probably priced at $ 125.00. Seems ridiculous for a small plastic end cap. Does anyone have any better suggestions or solutions?
As always. thanks for any help!
Brian
funfyzics is offline   Reply With Quote
Old 04-30-2019, 08:09 AM   #2
Photos?
Days Camped: '16=46 '17=30 '18=51 '19=36
Old 04-30-2019, 08:37 AM   #3
Sorry! Here are pics of end cap
I hope theses pics are here!!!!
ID:	203236   Click image for larger version
ID:	203237   Click image for larger version
Old 04-30-2019, 08:41 AM   #4
Witch Doctor's Avatar
Check eBay, is this it?Click image for larger version
Coachmen M/H
Concord
2018 / 300 DSC
Old 04-30-2019, 07:52 PM   #5
Try an RV Salvage Yard?
Larry
Larry-NC is offline   Reply With Quote
Old 05-01-2019, 07:56 AM   #6
Donít trust the build sheet
I had a similar experience with needing to replace the plastic end caps on my awning.
My experience was the information on the build sheet was not at all helpful.
The key that unlocked the mystery was to take a picture of the Dometic label on the awning roller which is only visible when the awning is fully extended.
The info. on that label was what my dealer needed to get me a replacement set of the plastic covers.
In my case, the covers apparently blew off while on the road because when I arrived at my next campsite, only the back portions that were held against the side of the trailer (when the awning is closed) were there, the outer pieces were nowhere to be found.
I caní t comment on cost, since my replacement was warranty.
Hope this helps.
2018 F250 CCSB 6.2L 4X4
2019 Flagstaff 27RKWS
CommTech is offline   Reply With Quote
awning
