Old 01-27-2019, 06:05 PM   #1
Awning Fabric Replacement
I'm looking for suggestions for replacing sun rotted awning fabric including brand and source. I'm guessing it can be slid in to the groves on the side of the RV and extending roller. Thanks in advance.
Glampen is offline   Reply With Quote
Old 01-27-2019, 06:21 PM   #2
Measure yours, EBay is your FREIND. YouTube has many vids showing you how to do.
Decon Blue is offline   Reply With Quote
Old 01-28-2019, 07:42 PM   #3
Ours seems to be cracking also
Ours is 4 years old and seems to be weathering bad where it is attached to the camper. I have seen acrylic is advertised to be less prone to mildew, but have also seen vinyl (which I believe ours is) is also suppose to resist mildew, which ours didn't.
jpauley4 is offline   Reply With Quote
Old 01-28-2019, 07:54 PM   #4
AudiDudi's Avatar
Yes, having done this, it does just slide into the grooves on the roller and side of the RV.
If it is a manual awning, you may need to drill out the rivets on the roller and you will need to retension the roller so count the turns.
Mike and JoAnne
Montana Summer / Arizona Winter
2016 Prism 24G /2002 HitchHiker 38LKTG
ACME EZTowing a 2015 Chevy Sonic RS Hatchback
AudiDudi is offline   Reply With Quote
Old 02-25-2019, 10:39 AM   #5
I have the same problem with my Awning Fabric. Could I use this:
https://www.alekoproducts.ca/ALEKO-A...bluwt03-ac.htm
or does it have to be from the Rockwood?
DreKat is offline   Reply With Quote
awning, replacement
