Old 02-25-2019, 10:43 AM   #1
Awning Fabric Replacement
Hi all
I just bought a mint 2006 Rockwood Roo 19 and we are very excited. The only problem that we have found is that the awning fabric is falling appart.
Im going to replace it in the spring but does the fabric have to come from Rockwood or could I order it from ebay, amazon etc?
Thanks and happy camping
DreKat is offline   Reply With Quote
Old 02-25-2019, 12:15 PM   #2
Witch Doctor's Avatar
Originally Posted by DreKat View Post
Hi all
Don't know about Amazon, but you would order it from Dometic directly you do not need to go through a dealer, the stealer is just going to tack more money on it, unless your having them replace it. Easy to do with 2 people....
Coachmen M/H
Concord
2018 / 300 DSC
Old 02-25-2019, 12:18 PM   #3
I was thinking of just buying it from this link:
https://www.alekoproducts.ca/ALEKO-A...bluwt03-ac.htm
Old 02-25-2019, 02:00 PM   #4
I really don't know how they attach to the channel mounted on the outside wall and how you slide it thru the roller. Things you should check, not all will work with your unit. Only company's that I know off that will work for sure are Dometic and Carefree. Those are the standards on 98% of all trailers. Good luck....
Coachmen M/H
Concord
2018 / 300 DSC
Old 02-25-2019, 02:31 PM   #5
Also, you need to make sure the size of it stretched out. Saying that when the frame opens it , it ends up tight, Dometic and Carefree are made to that size, so you need to measure from the camper wall to a fully extended awning , if there's is longer or shorter you will have a problem down the line with your awning hardware.
Coachmen M/H
Concord
2018 / 300 DSC
Old 02-25-2019, 02:39 PM   #6
What web site would you recommend me looking at for replacement fabric?
thank you so much for all of your help.
Old 02-25-2019, 02:46 PM   #7
Just Dometic, Google them, on your roller there should be a sticker with the part # they can cross reference and get you the right awning, they are all different sizes. Probably and I'm guessing between 150 and 250 depending on size, I had to order new toppers 1 time and just called Dometic C/S
Coachmen M/H
Concord
2018 / 300 DSC
awning, replacement
