Old 06-28-2016, 07:51 AM   #1
Awning hold down inside track
Hi all on a 19-day trip with our new Crusader 296 5th wheel and itís been great so far. Just noticed on one side of my Dometic awning that the hold down that fits inside the track (round black plastic type tube) held in position by a screw is missing. Looked on line but I canít seem to find what this parts called. Can anyone point me in the right direction? Will post a few photos later of what I am refereeing to if it helps.
esmoglo is offline   Reply With Quote
Old 06-28-2016, 08:07 AM   #2
TURBS's Avatar
Pictures are worth a thousand words.
Sent from my SCH-R530U using Tapatalk
Old 06-28-2016, 08:13 AM   #3
Yes, pictures would help.
On a Dometic electric awning there is a rubber bumper (kind of looks like a slice of tube) on each side but it is not plastic.
There are also plastic tracks that conceal the wiring but they look nothing like a tube.
We are all just guessing without photos.
Days Camped: '16=46 '17=30 '18=51 '19=42
Old 06-28-2016, 09:57 AM   #4
Yes photos are what's needed for sure and here they are.
One you can see a white holder with a screw in it.
The other photo you can see noting is holding the awning in the track and I need to fix this not worth taking this to the dealer its a DYI for sure.
ID:	112471   Click image for larger version
Old 06-28-2016, 10:14 AM   #5
bubbles's Avatar
That screw is just holding the extra awning mounting bead in place and it was done so the awning will not shift in its mounting. No need for a screw on the other end. You're good to go. Not an issue.
Old 06-28-2016, 04:22 PM   #6
Stormrider151's Avatar
As said before it's just a screw to keep the awning in place. I have seen the material pull out of the channel on one of my previous trailers. Since then I have added screws to the awning to prevent the material from pulling out of the track. It's your call. It will probably be fine as is.
Retired Fire Dept Battalion Chief
2016 Ever-Lite 232RBS
2012 F150 FX4 W/Max tow & Ecoboost (Best tv ever)
2018 F250 Lariat (ok but I miss my F150)
Getting old ain't for wimps!!!
Stormrider151 is offline   Reply With Quote
Old 06-28-2016, 09:01 PM   #7
Thanks for the replyís there was something their before holding back that tab but guess what ever it was fell off. Thereís slack on that end of the awning now the other side is fine.
awning
