Old 07-10-2013, 04:47 PM   #11
Witch Doctor's Avatar
Originally Posted by kopy kat View Post
Awning material is centered-no problem there that I can see.
The issue as far as I can determine is the "outer arm" does not slide over / cover the "inner arm" at the top. I cannot see a way to adjust anything to correct this issue.
Have someone press the button, when you start to get close hit the arm in and see if it will close up even that way. I had to push my arm over a little one time and never had a problem since, These auto awning arms are not built to well, I really like the manual a lot better.....
Coachmen M/H
Concord
2018 / 300 DSC
