Old 03-25-2015, 10:36 AM   #11
TURBS's Avatar
The awning switch switches the ground from one wire to the other depending on which direction your going "in or out"
I bet one way works fine but blows fuse the other way?
Old 03-26-2015, 07:39 AM   #12
bubbles's Avatar
Actually, the switch switches both the 12 volt and ground motor input (simple dc reversible motor). But you could be right switch could be connected wrong.
Old 03-26-2015, 08:36 AM   #13
TURBS's Avatar
Well yes that's what I meant!
Old 03-26-2015, 09:33 AM   #14
Totally agree trdutch, when a fuse blows, it's virtually guarenteed the "fuse" was not the problem. Dealer is prolonging the issue, for whatever reason. Demanding to replace the motor would be the easiest and most practical (as opposed to the wiring to/from the awning motor) and see if the problem still exists. Process of elimination.
I realize the dealers are under pressure from "corporate" to not replace parts willy nilly when under warranty. The old part has to be sent back many times also. I experienced that with several parts on my 2860DS that went bad.
KQ2N is offline   Reply With Quote
Old 03-27-2015, 05:57 AM   #15
trdutch's Avatar
Dealer says they cannot just rewire the system until it pops the breaker every time the switch is hit,and right now (at the dealership) it's working
Raining today and we will see if that has any impact
I never saw a Hearse towing a Trailer
'71 Dads VW camper pop up Van
'78.....tents
'93 Coleman pop ups (I'm Dad)
'04 Fleetwood Jamboree 26q
'14 Sunseeker 2860DS
trdutch is offline   Reply With Quote
Old 03-27-2015, 06:31 AM   #16
trdutch's Avatar
Ya but remember
The fuse tripped repeatedly from factory setup and the switch was replaced so that would mean it was wired wrong at the factory and the the dealer tech replaced the new switch "the way the old one came off"
We don't have a problem of it failing in transit or failing in the out position
As was suggested earlier it's either getting wet and that's when the short shows it ugly head or while I'm driving and the rub may be occurring
We are still trouble shooting but it's apparently working for the dealer now
Rain most of today and that should give us our "moisture test"
I'm not happy about taking it back "with a handful of fuses", as was suggested by the dealer
I operate large equipment and a circuit breaker of a fuse tells us something is WRONG
We don't use them to replace switches
'78.....tents
Old 03-27-2015, 06:51 AM   #17
TURBS's Avatar
So does it go out ok but blows fuses on the way in or the other way around?
Or do you have troubles both ways?
Old 03-27-2015, 07:01 AM   #18
Herk7769's Avatar
Ask them to drive it around; then run the awning in and out.
If there is a wire cut that only shorts during vibration, maybe it will appear after a road test.
HAM CALLSIGN - KC3FFW
Old 03-27-2015, 07:04 AM   #19
B and B's Avatar
Water won't cause a short on the line at 12 VDC. Eventually it will corrode. If the awning blows the fuse when it is fully deployed see if the awning roll is mechanically jammed or stuck, might be causing stall current to climb and blowing the fuse.
2017 Heartland Bighorn 3575 Elite with Reese Sidewinder
2016 Ford F 350 SD PS 6.7 SRW Crew Pucks and Reese 18 K Elite
2013 Rockwood 8289WS 2012 Rockwood 2703 SS TT 2007 Golden Falcon 38FLA PM 1983 Corsair 21RB
2015 Ford F250 PS '13 F150 3.5 Eco '09 F150 5.4 l 1987 Merc Grand Marq 1982 Ford E250 CW
B and B is online now   Reply With Quote
Old 03-27-2015, 07:07 AM   #20
Herk7769's Avatar
OK, this really belongs in tech.
Merging these two threads.
awning
