Old 09-10-2014, 11:39 AM   #41
thegreatoutdoors's Avatar
Originally Posted by Beadyeyez View Post
We have a 2013 and the rail under the awning has the exact same leak. The pictures show the EXACT same joint and the bend on the corner. I think it's on purpose for some reason. We don't get water leaking inside the camper though. There is a shroud above the door that redirects the water leak down the side of the door. I am going to attempt to post pictures of it.
I think its poor design and an attempt to save money by not using more pieces than necessary.
I agree on the poor design, I don't think ours has the deflector over the door though. I will have to check when we the camper back from C.W. (AGAIN)
But I'm pretty sure it doesn't, I remember getting wet whenever we opened the door the door. I did try the "roofing caulk" method, only because it is a little more rubbery, but it still leaked. Now I think it leaks at the stitching on the awning itself.
2014 Salem 26TBUD
2014 Ford F-250 SuperCrew 4x4
2001 F150 SuperCrew(Retired from service)
thegreatoutdoors is offline   Reply With Quote
Old 09-14-2014, 02:59 PM   #42
Ours also leaked after sealing the join. Because the awning is high, water runs down toward the track that the awning edge is in and runs along the track. What I did there is I got up on the roof and ran a bead of silicone along the awning where it goes in the track.
2014 Salem 27RKSS
Burgeogull is offline   Reply With Quote
Old 09-14-2014, 08:22 PM   #43
VinceU's Avatar
I had one leak at the sewn seam just before the roof rail also. I couldn't believe that could leak but it just got worse. They sell seam seal, not sure what it is, I used clear silicone and smeared into all the sewn holes, no more leak. Repair could not be seen from under the awning.
VinceU is online now   Reply With Quote
awning, leak
