Old 07-12-2018, 09:04 PM   #1
Unhappy Awning ? Noise.
Rockwood Roo 2016
We just noticed that when bring in the awning. The Awning was making a noise. Is there a lubrication point? Or the Hydraulic arm needs a lubrication? Or can it be the motor? We did not have the noise opening is a few weeks ago. June 26. It has been open since. Can weather (rain) play a part in the noise. Thank you
SnoopyElva is offline   Reply With Quote
Old 07-12-2018, 09:35 PM   #2
Just as confused as you
Scrapper's Avatar
If you have the spring loaded cylinders like those used for minivan hatches (sorry don't remember what their called) you need to periodically wipe them down with light oil or silicon lube on a rag. If the sound is like a popping noise when you bring it in, it is the dirt and oxidation building up. My 9100 series awning does that when it's been out for a few days.
Richard & Jill
Old 07-14-2018, 04:35 AM   #3
Awning
Upon rolling awning up it seams slow and sounds like it is struggling. Is there a problem down the road ?
HotelcamperRuss is offline   Reply With Quote
Old 07-18-2018, 07:23 AM   #4
I have a similar question to hotelcamperRuss as our power awning goes out fine but when retracting it struggles and moves slowly and sluggish. I was thinking it was the gas struts but was wondering if anyone else had replaced theirs. Our rig is 9 years old so probably it is time to replace but haven’t been able to find any info via search.
2008 Georgetown 373DS
jmck1737 is offline   Reply With Quote
Old 07-18-2018, 07:34 AM   #5
clr
All of the pivot point need to be lubricated from time to time so that it does not make that noise when moving. It also helps to make the whole awning move easier when going out or in.
I just use spray lubricant on the pivot points.
Chuck & Sandra
Engineer/Teacher
2010 F350 CC 6.4
2015 Prime Time Sanibel 3601
clr is offline   Reply With Quote
Old 07-18-2018, 10:53 AM   #6
My awning started to make a loud grinding after a trip put the awning out when we got home
it goes out fine no problem but when I brought it in it was really slow and would stop wait a minute
would start working again. Inspected the motor the motor housing was cracked. Replaced motor
working great goes in and out no problem. Bought mine from etrailer.com 135.00 free shipping
Very easy to replace etrailer.com has the install instructions.
Gdub2 is offline   Reply With Quote
Old 07-19-2018, 02:48 AM   #7
Thanks for the replies. I will lube pivot points today and will look at motor and try to get a multi meter on it also.
Old 07-25-2018, 02:58 PM   #8
I spoke to a tech today in the campground we are at and he said it may be the awning is wound too tight. Any one with experience with this?
Old 08-25-2018, 06:36 PM   #9
my awning has a spring piston on each end. if I squirt shaft with silicon spray while open, it is quiet. this leads me to believe this us the rub. it is quiet for one pass then noise next time.
what would be a better lube for the shaft?
Larry L is offline   Reply With Quote
Old 08-25-2018, 07:09 PM   #10
rsdata's Avatar
I believe you have the best lube now... have you tried cleaning the shaft that you are lubing? there may be some oxidation on the shaft... using very fine sandpaper (400-600 grit) try sanding the surface which will remove the oxidation... then re-lube
2014 Shamrock 183
awning, noise
