Old 08-09-2014, 01:06 PM   #1
iluvlcy's Avatar
Awning noise
What could be causing our power awning to make a loud chattering and thunking type noise when retracting? No sound when extending but pulling in it is really loud.
Pam & Don
2003 Ford Expedition EB
2011 Rockwood 2304s
108 days camped 2013
74 days camped 2014 so far
iluvlcy is offline   Reply With Quote
Old 08-09-2014, 01:10 PM   #2
rattleNsmoke's Avatar
Try a lil' WD-40 on all pivot points Wipe the cylinder shaft down with a clean cloth too.
rattleNsmoke is offline   Reply With Quote
Old 08-17-2014, 06:42 PM   #3
I'm having the same problem. It is a shuttering/cluttering sound. Mine does it some on opening, but when closing, I'm concerned it isn't going to make it. I sprayed some lithium grease on it and it didn't improve.
forthefunofit is offline   Reply With Quote
Old 08-17-2014, 07:03 PM   #4
iluvlcy's Avatar
Awning noise
The wd40 seems to have worked for us. We did all pivot points.
Pam & Don
2011 Rockwood 2304s
Old 08-18-2014, 07:56 AM   #5
Thanks, I'll try that.
Old 08-18-2014, 08:35 AM   #6
I'd stay away from grease for this lubrication application. It will attract dirt and grime. It seems in my case, a good cleaning of all the hinge parts, apply the WD40 as indicated previously, and a little silicone applied on the polished part of the pistons (wipe clean after spraying), allows them to actuate better as they age.
Old 07-13-2015, 06:51 PM   #7
Thanks, I am having the same problem
Rcbstuff is offline   Reply With Quote
Old 07-13-2015, 06:54 PM   #8
Georgia Rally Coordinator
aceinspp's Avatar
have you loosened the knobs that are used to tighten when extended to help prevent wind blowing up? Later RJD
2018 Dodge Ram 2500 6.4 3:73 gearing. Traded 2015 Chevy 2500 6.0, 4:10 gear
Days camped 2017 62
Days camped 2018 67
Days camped 2019 57
aceinspp is online now   Reply With Quote
Old 07-13-2015, 10:41 PM   #9
I will give that a try
Old 07-24-2015, 04:08 AM   #10
mguay's Avatar
Mine is making the same noises... I've tried everything from WD 40 to silicone to penetrating oil and nothing has worked so far. I haven't tried wiping down the shafts on the cylinders yet.
2015 GMC Denali DRW
2014 Dynamax Trilogy 3715FB
mguay is offline   Reply With Quote
awning
