Old 06-27-2015, 06:53 PM   #11
Send a message via Yahoo to carluv
Thanks crunchman, will keep you posted. Be a few days until we get to our destination in Marshall,In.
Sid, that is kinda what the RV repair guy said.
carluv is offline   Reply With Quote
Old 06-27-2015, 07:07 PM   #12
Originally Posted by wana65stang View Post
OC, pop rivet both ends or is one enough??
Pop rivet both ends.
Daisy, you need to center the material and pop rivet the ends. The popping is with the arms not seating properly.
Old 06-28-2015, 01:51 AM   #13
What diameter and length of rivet did you use?
Carrier is offline   Reply With Quote
Old 06-28-2015, 07:44 PM   #14
Thank you Sir, Going to do this ASAP
2014 Forester 3051s
2016 Nissan Pathfinder SL
2012 Sonic toad
wana65stang is offline   Reply With Quote
Old 06-28-2015, 07:56 PM   #15
3/16" dia, 5/8" long, large head.
While you are doing this, inspect the arms very closely for possible worn spots and lube all the pivots with lithium spray. Look for any interference with the pins and the cutouts for the pins in the matching channels.
Old 06-29-2015, 11:26 AM   #16
I messed with mine a lot and find when partly out, the rear support which works fine. The lower pushing rod has good pressure but on the front support the lower rod just sits there. Finally partway out it suddenly "deploys" with the bang. I could manually help it and it wouldn't bang. Wind came up here and I quit but the final time there was no noise. Maybe lubricant worked in? No problem with the covering slipping.
Shorebird is offline   Reply With Quote
awning
