Old 05-06-2017, 04:17 PM   #1
PPST Wannabe
kenandterry's Avatar
Awning out of alignment when retracted
Recently noticed that our factory Dometic power awning on our Georgetown is not parking itself properly when fully retracted. It rolls up the awning, but at the final resting position, the moving arms do not straddle the brackets attached to the side of the actual motorhome like it should. I need to push/tap the outside moving arms slightly forward in order to straddle correctly. The moving arms obviously need to be re-aligned to their original position.
Any ideas how to re-align them and in what position should the awning be to make this easiest?
Ken and Terry
2010 Georgetown 330TS being pushed by our
2017 GMC Terrain toad (4 wheels down)
kenandterry is offline   Reply With Quote
Old 05-06-2017, 04:44 PM   #2
Deploy the awning and then center the material on the roller and pop rivet it thru the hems on both ends. Make sure it is centered and retracting before riveting.
Name:	Pop Rivet in Awning.JPG
Old 05-06-2017, 07:43 PM   #3
PPST Wannabe
So........when deployed, the awning will allow you to slide it in one direction or the other freely?
Ken and Terry
Old 05-06-2017, 07:53 PM   #4
It's not easily slid, but with a little effort, it can be done. Don't deploy it to the point the material is tight, just deploy it to the point there is a little slack at the roller.
Old 05-06-2017, 08:02 PM   #5
Also a helper makes it easier.
One on a ladder at one end pushing and the other on a ladder pulling.
Also, although it should have a screw through the awning rail at the trailer side, make sure it is centered and anchored there as well. I've seen a few that were missed.
Days Camped: '16=46 '17=30 '18=51 '19=42
Old 05-07-2017, 08:53 AM   #6
PPST Wannabe
Local weather temps have cooled significantly......it was much warmer in Florida a few weeks ago.
I'm thinking the warmer temps will make the adjustment easier, so I'll report back when I can address the issue of adjusting the awning material.
Ken and Terry
Old 05-07-2017, 12:23 PM   #7
Another adventure awaits!
HESN22's Avatar
Smile Glad you asked
We have the same problem ... will see if we can fix when we open up trailer next weekend ... if so, will try the suggestions received.
Good luck with yours
2018 Columbus Compass 377MBC
2013 F250 4 x 4 Supercab
HESN22 is offline   Reply With Quote
Old 05-07-2017, 12:33 PM   #8
DouglasReid's Avatar
There is another very similar method to use.
The awning is held in its track on the camper with two screws usually, one on each end. Remove the screws on the camper end of the awning. run it in and out a couple of times til it lines up correctly when rolled in. Then replace the screws on the camper end.
2008 Chevy Silverado 2500HD CCSB LTZ Diesel, Fumoto Oil Drain Valve, Turbo Brake activated, 39 gal Aux Tank W/ Fuel Pump transfer, Air Lift Loadlifter 5000 air bags.
DouglasReid is online now   Reply With Quote
Old 05-07-2017, 01:06 PM   #9
I did this with mine...spray a little silicone in the track on the side you need to pull it helps a little.
Also measure where it attach to the side wall...to make sure it is centered well.
Mine was off 3/4" and the holding screws where not holding the kind of rubber cord in the channel.
Black
2014 Ford F250 Lariat SuperCrew 4x4 tuxedo black
2015 Rockwood Signature 8310SS Diamond Edition
***3rd GENERATION EGG FARMER***
***WHO MADE YOUR EGGS TODAY ?
Black is offline   Reply With Quote
Old 05-07-2017, 01:24 PM   #10
Yah, I had the screws fall out of my awning, and when I wanted to retract it, I had to get up on the roof and give the awning a pull forward. New screws fixed that.
RussPastuch is offline   Reply With Quote
alignment, awning
