Old 05-29-2015, 09:56 PM   #1
Awning Problems
I have a 2014 Wildwood 27 RLSS with LCI power awning.
Since taking it out of storgage, I cannot get awning to extend.
I have power at switch.
When I press remote, here clicking.
Is there any fuse between switch and motor?
Anything else to check other than motor?
tmacneil is offline   Reply With Quote
Old 05-29-2015, 10:13 PM   #2
dcheatwood's Avatar
I've heard this before. Can you have someone push the "out" button while you gently tug on the forward arm? A friends was just stuck and this started it out.
Also, can you connect awning wires to a slideout switch to see if it works then? Could be bad switch.
2018 Forester 3011 DS
Old 05-30-2015, 05:51 AM   #3
Turned out to be "sticky" arm or motor.
There is an access plug on the motor. Took this out and there is a nut you can turn that extends or retracts awning. Turned this a few times, pressed remote and it worked.
Is ther any recommended lubrication for the motor or gear?
Old 05-31-2015, 04:38 PM   #4
dcheatwood's Avatar
Good. Love a simple fix. I use white lithium with the red straw attached to hit right where I want grease.
awning
