Old 08-22-2014, 06:18 PM   #1
Awning racket when opening or closing
I have a surveyor cadet sc 226rbds. The awning shutters and makes a racket when I open or close it. Has anyone been able to figure out what causes it.
Started Out With Nothing,
Still Have Most Of It Left!
jwedell is offline   Reply With Quote
Old 08-22-2014, 08:35 PM   #2
Dave_Monica's Avatar
Have you tried lubricating the pivot points and the rod end of the cylinders?
Dave
Old 08-22-2014, 08:36 PM   #3
Originally Posted by Dave_Monica View Post
Have you tried lubricating the pivot point and the rod end of the cylinder?
Dave
Yes every time but no change.
Old 10-14-2014, 11:01 AM   #4
arpipeliner's Avatar
Mine does it too. Sometimes more than other. Sometime it goes out quiet and smooth.
Wonder if it's the spring in the tube. More tension or out of alignment on the frame. Trying to find the post where to pop the fabric to the tube. Don't want to put in a bad place.
arpipeliner is offline   Reply With Quote
Old 10-14-2014, 07:11 PM   #5
gooiebob's Avatar
Ours use to do that until I wiped down the shafts of the struts. Also I secured the ends of the awning on the roller. It would change positions and one side would roll at a different angle and bind on one side. When it rolls up smooth with no wrinkles it cured the noise.
2019 Della Terra 29k2s
2014 Toyota Tundra 5.7
gooiebob is offline   Reply With Quote
awning
