Old 03-19-2012, 09:56 PM   #1
Awning replacement question
I purchased a used rv.The 21' awning needs replacing because the roller tube is bent or bowed due to being parked so long. Can the tube and awning be replaced , the hardware that is attached is still in good shape.Also how can you prevent the bow or bending from occuring on a long canopy like this?
hldurham is offline   Reply With Quote
Old 03-19-2012, 09:58 PM   #2
papap's Avatar
They make a bracket for in the center during travel.
2016 Forester 3171DS
Work 28 and 28 around the world.
Camp every chance we get
papap is offline   Reply With Quote
Old 03-19-2012, 10:10 PM   #3
If you get a helper, you can remove the awning and straighten it. Just be VERY careful when you disconnect it from the trailer.
Old 03-20-2012, 05:12 AM   #4
cardinal4fun's Avatar
If bowed you may beable to straighten it, to a usable point. If bent you will need to replace. They make a center support post that when traveling supports the awning and keeps it from bouncing. A lot of times however the awning roller gets bowed due to heavy rain where the awning does not allow for run off, but instead holds the water causing the roller tube to bow.
3500 Ram 5.9l diesel
08 35 RLT Cardinal
5th Airborne Pin Box
cardinal4fun is offline   Reply With Quote
Old 03-20-2012, 07:01 AM   #5
TURBS's Avatar
Ditto! I had a 20 foot awning and it never bent with no center
support.
someone didn't slope or in a rain storm..
Old 03-20-2012, 10:10 AM   #6
You can buy just the tube and fabric. You need to find a set of directions, and make sure you lock the tube before you swap it. The tube is spring loaded, and will hurt when removed if not locked properly. If you need further help, search on here, or the awning manufacture website, or shoot me a private mail. Send a pic of the left end of the roller tube, and maybe I can locate the locking holes for you.
LadyWindrider
2012 Ford F250 ext. Cab 4x4
2002 Jeep Wrangler Sahara
2008 Work and Play 18LT
Old 07-10-2012, 08:36 PM   #7
DDC
DDC's Avatar
I have a 2012 surveyor 264sv and it has a 20 foot awning but it has a bow in it and the fabric is always wrinkled, dealer has said this would be ok but I have my doubts any advice.
Cedar Creek Silverback 33IK
Donald&Casey cairn terrier
DDC is offline   Reply With Quote
Old 07-10-2012, 09:17 PM   #8
This is a good fix that will straighten bowed tubes and keeps it from bending.
Plus it is cheaper than a new tube. The tubes can be manually straightened, but it takes 2 people and some very creative straightening methods. My son and I straightened a 19', but it took us about 3 hrs just to straighten the tube as we tried numerous methods til we figured out how to hold the tube and progressively bow it til we got it straight. A tremendous amount of trial and error.
Watch the videos, this is a lot easier than what we did.
MX57 (*Single unit) - MX57
awning
