Old 12-10-2018, 07:18 PM   #1
Awning rotting at furthest awning tube.
Good evening. I have a 2013 Cougar 318 SAB 5th wheel. i noticed my awning is starting to rip away from the tube that is not at the RV side. It is about 6 inches now but seems to be growing. I am trying to determine if it can be fixed rather than having to have it replaced. Picture enclosed. Thank you for your time.
Name:	Awning 2013 318SAB 5th wheel .jpeg
sanduskyjack is offline   Reply With Quote
Old 12-10-2018, 08:45 PM   #2
Maybe hand sew a patch there as a crutch for a few trips.
You will need new awning soon
Tblt44 is offline   Reply With Quote
Old 12-10-2018, 09:09 PM   #3
Flybob's Avatar
Appears to be along the stitch line. You may be able to have a new bolt sewn in. Awning would be about 1 1/2" shorter.
2015 Freedom Express 248RBS
TST Tire Monitors
Honda 2000I + Companion
2 100W solar panels
Old 12-10-2018, 10:17 PM   #4
NMWildcat's Avatar
Once you start having tears anywhere, it's only a matter of time until you will be forced to replace the fabric. You can usually catch a sale and install yourself to save $$$. Not that bad a job and lots of videos available to help you out.
Have never seen any kind of awning patch that lasted more than a year, depending on how how often you use your awning.
Scott and Liz - Southern NM
NMWildcat is online now   Reply With Quote
Old 12-10-2018, 10:21 PM   #5
Oaklevel's Avatar
The fabric will need replacing soon. Being a 5-6 year old awning, if it has seen a lot of sun I am not surprised that the fabric is seeing the end of its life.
2005 Dodge 3500 Cummins
2017 Wildwood Lodge 4092 BFL
1966 Mustang GT
1986 Mustang SVO
Oaklevel is online now   Reply With Quote
Old 12-11-2018, 02:35 PM   #6
I would try some eternabond tape first. I have replaced the fabric on mine. Fairly simple to do
shadows4 is offline   Reply With Quote
Old 12-11-2018, 03:50 PM   #7
buffalohunter's Avatar
X2 on tape. It will prolong the life of the awning. I have also replaced two trailer awnings. Two ladders and two persons needed. You tube videos very helpful.
2012 Rockwood Windjammer 3008 W
2007 Tundra Reg Cab 4X4 SR5 5.7L
buffalohunter is offline   Reply With Quote
Old 12-11-2018, 07:30 PM   #8
Thank you all for your suggestions and also for how rapidly you responded. I now know what to do. Best Regards.
Stan.
Old 12-11-2018, 10:00 PM   #9
Canadian Member
Looks like a job for duct tape until you can replace the fabric.
2019 Rockwood Signature 8290BS
Old 01-04-2019, 09:51 PM   #10
Put some external bond tape on both sides. Clean good first.
quick83 is offline   Reply With Quote
awning
