Old 08-15-2011, 07:15 AM   #1
mTn_biKer65's Avatar
Awning spring clip missing spring
The awning on my 2007 19' Shamrock has been missing a spring clip on one of the support arms since it was purchased used by me a couple years ago. I currently use a velcro strap to keep the clip in place when it's working but it would be nice to replace the spring if it's an easy fix.
The spring clip I'm referring to is near the top of the support bar that sits roughly 45 degrees when the awning is extended. The clip in question holds the vertical support bar in place again when the awning is extended.
Is there a way to get access to the clip and return a spring to the assembly? Next challenge I guess would be to find the correctly sized spring.
Paul
Nights camped
2007 Shamrock F19 hybrid - 2010 (22 nights), 2011 (24 nights), 2012 (11 nights)
2013 Surveyor Select 235RKS -
2012 (6 nights), 2013 (32 nights), 2014 (26 nights), 2015 (37 nights), 2016 (14 nights)
mTn_biKer65 is offline   Reply With Quote
Old 08-17-2011, 07:30 AM   #2
Guess I'm the first to loose the spring from the awning clip.
I'll report back if I can manage a fix.
Nights camped
awning
