I will help you but as it snowed 3 inches last night/today it will take until next week before I can get a picture as I am leaving Thurs for the weekend.
Basically Old Coot sells a bracket that bolts to the end of the awning arms at each end near the roller. This bracket uses existing holes in awning arms. It gives you the ability to pin a telescoping support pole to the bracket that will extend to the ground. Also on the bracket is another short arm with a hole that you will use to attach a ratchet strap to a ground stake to fasten the awning to the ground. So pole holds awning up and strap holds awning down... between them the awning is stabilized against wind and rain. Best to keep awning tilted from left to right in case of rain and poles slide into one-another to accommodate different lengths.
Now picture some CPVC (white rigid) plastic tubing from Home Depot, 1 inch sliding into larger 1 1/4 inch tube that is pinned to the bracket at top and goes down to the ground. The sliding pole is adjustable in and out and with holes drilled into the tubing at various points that can also be pinned at various lengths to accommodate differing awning heights to the ground. I think post #2145 on the other thread shows this in a picture.
this thread here >>>
Awning pole hold down kit
One post in this thread I mentioned above talks about using rigid metal conduit in a similar way as the plastic. Another member here sells aluminum poles already made for this purpose. Up to you to decide how fancy you want to get. CPVC is light to carry and cheap to make. Over all pole length using 10' pipe is about 5 foot 6 inches collapsed.
I will do a write-up with pictures next week and post here on this thread...
