Old 04-28-2014, 08:24 PM   #11
DaGrinch's Avatar
Finally Installed...
I finally got the time (and guts) to attach the awning cradle on the Flagstaff 27BESS. DW walked into the house rather than watch me drill 6 holes - 4 for the pop rivets and 2 for the large screws. Of course, I filled all the holes, and a little outside, with caulk for waterproof reasons. I could have set it a little higher, but it still supports the awning sufficiently.
"Sunny" the 2017 Sunseeker 3010DS
2006 Jeep Liberty Toad
.... and lovin' life........MOST of the time.
DaGrinch is offline   Reply With Quote
Old 04-28-2014, 08:31 PM   #12
mark0224's Avatar
Did mine today
ID:	51186   Click image for larger version
ID:	51187   Click image for larger version
mark0224 is offline   Reply With Quote
Old 04-28-2014, 08:41 PM   #13
Plain Old Member
We installed one of those I think on every camper. Awning now is 21' I believe. I accidently installed mine lower than I wanted, but it still works. Waited till a morning dew where I could see, and mark where the studs in the wall were where I didn't hit something I didn't want to. Still scary when you drill holes in the side.
John and Rebecca Dickson
Emma-7 / Little John-5 / Iva-1
Full Timing Again, Rev B
2013 Ford F-350 Lariat CC LB PSD
2015 SOB TT - With OC's Awning Poles (#8)
At least in Heaven, RVs will be perfect, and I won't have to keep fixing them.
BigJohnD is offline   Reply With Quote
Old 04-28-2014, 09:41 PM   #14
Old Bones's Avatar
Looks good. I may have to get something like that for our awing. It's 18'.
2013 Forest River Surveyor SP296
Old Bones is offline   Reply With Quote
Old 04-29-2014, 08:02 PM   #15
I went with the carefree one. The reason I went with the carefree one as it uses the same wall bracket as the rafter vi and rafter vii so the rafter units will bolt directly to the existing bracket I have on the trailer now(when I can afford to get a rafter unit).I have a 21 FT awning.
2012 Palomino Ultralite T245
2004 F250 Supercab 5.4L
09 Grizzly 700 EPS
09grizzly1 is offline   Reply With Quote
awning
