Old 06-20-2016, 06:00 PM   #1
Awning top rail pulling out!
Hi all! Has anyone had the top rail of the awning pull out from the trailer?! Is this an easy fix? It's a 2014 Wildcat Maxx 313RE. My main concern, other than the whole thing pulling out, is water getting in where the screws are pulling out. Thank you for any input!
atcla is offline   Reply With Quote
Old 06-20-2016, 06:35 PM   #2
crunchman12001's Avatar
Looks like the factory missed the studs... you will need to locate the studs and re attach with self tapers. Fill the old holes with dicor.
2015 F-250 FX4
Old 06-21-2016, 09:31 AM   #3
Thanks crunchman! How do you find the studs on these? Finger tap method or will a stud finder work?
Old 06-21-2016, 11:27 AM   #4
waiter21's Avatar
If you have access to an infrared camera, you may be able to see the studs after pulling the awning off and let it sit in the sun for a few hours.
2001 Coachmen Mirada (Ford F53 6.8L V10) - Toad 2003 Saturn Vue
It won't do MACH 2, but I can get a sandwich and take a pee.
waiter21 is offline   Reply With Quote
Old 06-21-2016, 12:53 PM   #5
Telstar's Avatar
We had the same problem with our 2005 Cardinal 5th wheel and Dometic auto awning. Thing is that the mounts don't go into the metal studs, gust the gel coat wall. My shop used rubber expandable plugs which solved the problem.
Gary and Donna
2005 Cardinal 33TS-LX
Trail Air pin box
Center Point suspension
2018 Ram Laramie 3500 6'4" box 2WD
Demco AutoSlide 18k
Telstar is offline   Reply With Quote
Old 06-21-2016, 06:20 PM   #6
A good old trick, fill the screw hole completely with toothpick soak in wood glue.
Wait a day and reinstall the screws.
Jonol is offline   Reply With Quote
Old 06-21-2016, 10:24 PM   #7
No access to an infrared camera! Telstar, I was thinking along those lines of putting some kind of plug or anchor to screw into...or even the toothpick idea might work!
Old 06-21-2016, 10:58 PM   #8
Left Coast
Use the next size larger and longer screw......and caulk, and drive screws in manually....then invest in a set of awning poles....
Old 06-21-2016, 11:05 PM   #9
I like your idea bob, simple and quick! I'll try that first and see if it holds! Thank you everybody for the suggestions! Best forum ever!
Old 06-22-2016, 07:08 AM   #10
Wolverine 1945's Avatar
I would look to see if screw anchors might work !!!
Tooth picks or wooden matches & wood glue,,, are great for furniture repair !!!
LOL !!!
Wolverine 1945 is offline   Reply With Quote
awning
