Old 05-21-2016, 05:11 PM   #1
Awning trouble
I own a 2014 Salem 26tbud. Got it out of storage this week and the power operated awning operates intermittently. At the moment it is extended and will not retract. While I wait to diagnose the electrical issue, is there a manual operating mode? The only marking I find are "LCI".
Westphalia is offline   Reply With Quote
Old 05-21-2016, 05:23 PM   #2
Timex's Avatar
OOOooo..... that's bad.
Those are bad letters for many of us.
Sounds like a switch, loose ground, or a loose hot wire.
2012 Flagstaff V Lite 30 WRLTS
2005 Dodge Ram 2500 5.7 Mag Hemi 3.72 Rearaxle
Nights camped 2015 = 23
Nights camped 2016 = 25
Nights camped 2017 = 13
Nights camped 2018 = 3
Timex is offline   Reply With Quote
Old 05-21-2016, 05:46 PM   #3
Iggy's Avatar
If your batteries are fully charged I would first look at the awning switch.
If you tap on it the contact may have some garbage (sawdust) in there maybe.
If that doesn't work it is probably the motor.
The switch takes +12 and -12 volts and reverses the polarity to go in or out.
Here is a generic awning switch and how it looks inside .
2012 Georgetown XL - 378TS 66K + miles
Old 05-23-2016, 11:04 PM   #4
tuckerdog1's Avatar
My last TT had a really weak retraction of the awning. I was concerned I'd get in the middle of nowhere, roll it out & not be able to get it back in. Nothing in the owner's manual. Several calls for info yielded zip. But found this on YouTube tonight. Might help.
Tuckerdog1
2016 RAM 2500 Cummins SLT Lone Star 4X4 LB ( Mine )
2015 Genesis 5.0 ( Hers )
2016 Windjammer 3029W Platinum ( Ours )
I'm not an expert. But I play one on the internet.
You live & learn or you don't live long.
tuckerdog1 is offline   Reply With Quote
Old 05-24-2016, 02:12 PM   #5
Timex's Avatar
Tuckerdog1
That was a bad link. Lead me to gmail.
Old 05-24-2016, 02:20 PM   #6
Retired JSO's Avatar
My last RV, had a carefree electric awning which died on the road. No fix other than a new motor. I bought another awning this time a dometic 9100 and it died less than 18 months. I then went back to manual awnings. If you use them like we do, they apparently won't last.
Retired JSO is online now   Reply With Quote
Old 05-24-2016, 02:22 PM   #7
Wobbles's Avatar
Can you post a picture of the awning? The top of a roller end would help. Mine is a Solera, owned by LCI and has a little cap on the end where the motor rides, it can be removed. When removed a cordless drill with the right socket can be used to manually retract or extend.
Bob & Michelle
2016 Ford F-250 Lariat 4x4
2017 Flagstaff Super Lite 526RLWS
Wobbles is offline   Reply With Quote
Old 05-24-2016, 02:24 PM   #8
Wobbles's Avatar
Sorry Timex, that was meant for the OP.
Bob & Michelle
Old 05-24-2016, 02:40 PM   #9
Wobbles's Avatar
I have circled what my cap looks like. Hope it helps...
Bob & Michelle
Old 05-24-2016, 05:14 PM   #10
tuckerdog1's Avatar
Sorry about that link. Hope this one is better
Tuckerdog1
awning
