Old 03-12-2016, 09:20 PM   #1
Awning will not fully extend
While getting ready for our first trip this spring, I extended the awning and it would not extend all of the way. It looks like it is about 4-6 inches short from fully extending based on the flap overlapping over the end of the awning. As a result, the awning cover was not tight and had a sag in it. It was fine when we used it last fall.
Any ideas or suggestions?
sowbug is offline   Reply With Quote
Old 03-12-2016, 10:54 PM   #2
TURBS's Avatar
Did you try to unroll it by hand the rest of the way while someone hit the switch?
2015 Columbus 320RS
2008 2500HD Duramax
2015 nights camped "34"
Old 03-17-2016, 11:54 AM   #3
Thanks. As it turns out, it was fully extended. I had forgotten that there is a flap hanging down on the end. All is good. Another newbie duh moment.
Old 03-17-2016, 03:56 PM   #4
TURBS's Avatar
FYI you shouldn't fully extend your awning anyway or water can pool on it.
You should leave about half a wrap of awning material on the roller.
2015 Columbus 320RS
2008 2500HD Duramax
Old 03-17-2016, 03:58 PM   #5
heavynlori's Avatar
2015 Columbus 320RS
2008 2500HD Duramax
X2 - the flap should hang straight down towards the ground under the roller to leave the proper amount of tension around roller to avoid water pooling
Sent from my iPhone using Forest River Forums 🇺🇸
heavynlori is offline   Reply With Quote
Old 03-17-2016, 04:31 PM   #6
Thanks... Looks like it's working the way it should.
awning
