Old 09-10-2018, 08:40 AM   #1
Awning won't extend
Next Problem:
When I press the button to extend the awning I hear a "click" but it won't extend!
Nothing was done on it....
Any help ?
RV 2018
ID:	185978   Click image for larger version
ID:	185979   Click image for larger version
FRCSupLite is offline   Reply With Quote
Old 09-11-2018, 06:32 AM   #2
SeaDog's Avatar
Is the clicking coming from the awning motor if so you might try to pull out on the awning while someone hits the switch and see if it moves. Just a thought
Retired Navy
Jake my sidekick (yellow Lab)
2016 Flagstaff 26 FKWS
Old 09-11-2018, 06:40 AM   #3
Do you have the control panel with mechanical rocker switches or the one with the touch pad? The touch pad uses relays to control the voltage to the motor and may be the 'click' you are hearing.
Have you checked for voltage?
Do you own a multimeter and know how to use it?
Days Camped: '16=46 '17=30 '18=51 '19=36
Old 10-15-2018, 02:24 PM   #4
D W
D W's Avatar
X2. It is possible that that the support is jammed into the channel. The motor spring could have been over-clocked when the awning was last retracted. At any rate the awning will have to be pulled out manually (consult the manual), as the wiring to the motor is located inside the tubular channel.
'04 K3500 Silverado LS with LS3 Connect & Cruise- with Intimidator Mods- Reprogrammed 4L80E
2016 Salem 27RKSS (Pacific Northwest Build)
D W is offline   Reply With Quote
awning
