Old 08-18-2010, 11:54 PM   #1
GS_Rider's Avatar
Baggage compartment latch broken door shut
Hi all!
We were getting to take our first trip out in our (new to us) 2002 Reflection, when I went to throw in a new black water rinse hose in the sewage/water connection compartment, I grabbed the handle and you guessed it "plink" and a free moving handle and a closed compartment door. I opened and closed it 2 minutes prior with no issues.
It's the flush paddle style latch/handle. It feels like the connection from the cams that the paddle attaches to and whatever pulls up the tapered latch no longer like each other.
Any suggestions on how to open this thing without door damage?
I was thinking: Drill a small hole 1/8" or so in the botton/underneath where the latch catch is and hopefully feed something in to push up on the tapered latch plunger.
GS_Rider is offline   Reply With Quote
Old 08-19-2010, 09:26 AM   #2
GS_Rider's Avatar
The culprit. No drilling required just my long arm. Unscrew hole cover, shove long arm with socket and remove latch. 15 minutes to remove. Now to find the part.
Old 08-19-2010, 11:31 AM   #3
CLASS "A" Senior Member
cfsoistman's Avatar
They're a pretty standard door latch. I would think an RV Parts store should have it or at least have a catalog that shows it.
http://www.pacificrvparts.com/prodse...DID=50&CID=569
http://www.trimarklocks.com/baggage.htm
Is it similar to any of these?
2007 Georgetown 370TS
aka - RAYNMKR
Driver: Charlie
Navigator: Sheri
cfsoistman is online now   Reply With Quote
Old 08-19-2010, 11:05 PM   #4
GS_Rider's Avatar
Nobody had one. So over to ACE 1 length of 1/2" wide 3/16 thick flat bar 30 minutes later a beefed up steel version of the pot metal one.
Thanks All for the messages!
Safe Travels!
