Old 08-25-2016, 10:52 AM   #11
May I expand the discussion? I have the same issue. I'm needing to remove the top track, I'm assuming, to replace the above-mentioned part.
My question --- is there any magic song-and-dance in getting the track aligned when putting it back on?
Larry Tiner is offline   Reply With Quote
Old 08-25-2016, 10:53 AM   #12
Just align the screw holes...
stantyszka is offline   Reply With Quote
Old 08-25-2016, 11:02 AM   #13
Thank you. I was praying it was this simple.
Old 08-25-2016, 04:12 PM   #14
Thanks for that confidence-building tip. Everything went well. The pulleys in the tract had one facing one way and the other facing opposite, so I reversed one of them.
Old 11-15-2016, 09:35 PM   #15
updhaul's Avatar
In the off-chance at this late date some one else runs into this problem.
The woodwork around the track is stapled so I separated it to replace rollers and then replaced the brad staples with screws. Then I added a second bottom door guide to bottom wall to keep it in place when open. So far so good. Stayed in place all last year
updhaul is offline   Reply With Quote
bed, door, roo
