Old 08-04-2016, 11:18 PM   #1
Bedroom sliding door stop missing on 2015 320RS
The sliding door in the bedroom of my 2015 320RS is going off the lower guide when I open it. There use to be a stop to keep it from opening too far. It looks like the stop may have been attached to the next to last screw based on some debris I see on the screw. Would someone with a similar door please look at the stop and tell me how it works so I can replace mine? It looks like my pictures may upload sideways. If they do sorry as I don't know why.
Sent from my SAMSUNG-SM-N910A using Forest River Forums mobile app
ID:	116345   Click image for larger version
ID:	116346   Click image for larger version
bobneal69 is offline   Reply With Quote
Old 08-04-2016, 11:20 PM   #2
[QUOTE=bobneal69;1281064]The sliding door in the bedroom of my 2015 320RS is going off the lower guide when I open it. There use to be a stop to keep it from opening too far. It looks like the stop may have been attached to the next to last screw based on some debris I see on the screw. Would someone with a similar door please look at the stop and tell me how it works so I can replace mine?
Old 08-05-2016, 11:11 AM   #3
I have a different unit but similar door design. I took the TOP door trim cover off (basically put in with staples) and put a screw through the top rail where I wanted the door to stop. Carefully put the trim cover back where it was originally installed and added a couple of colored trim nails long enough to catch framing. Worked for me. Good luck
Hog wild is offline   Reply With Quote
Old 08-05-2016, 11:49 AM   #4
Just screw in a small piece of wood for the stop
If not camping, I am Sailing
JohnVtx is offline   Reply With Quote
Old 08-05-2016, 12:32 PM   #5
rockfossilman's Avatar
Same thing happened to me with our 2016 29 06 was. It appears that the stopover mine was a 6 cent 1 1/4" screw turned just 2 threads into the ceiling through a hole in the track.
I used a longer screw through a bushing to soften the hit when opening the door. Working well so far.
Rockfossilman - Western PA
Rockwood UL 2604ws - 2013 F150 w/MaxTow
"I'm a man, but I can change, if I have to. . .I guess."
Red Green
"Quando Omni Flunkus Moritati"
rockfossilman is offline   Reply With Quote
320rs, bed, door, roo
