Old 09-23-2015, 09:36 PM   #1
Bent awning arm
I was closing my awning and something was in between it and side of camper bent the top arm. Question is can it be straightened.
Mattman06 is offline   Reply With Quote
Old 09-23-2015, 09:45 PM   #2
Maybe a Little hint at what kind of awning would help! Youroo!!
Old 09-23-2015, 10:18 PM   #3
It's a dometic I believe the bent is the alum c channel that's the top arm
Old 09-24-2015, 01:00 PM   #4
Jack350's Avatar
Mine was bent by the wind.. Dometic only sells the entire arm unit. I think the part was $350. Only needed the u shaped arm section.
2017 Open Range RES 347, 2017 F-350 4X4 LWB 6.7.
Hayes Autoformer, Moryde SRE 4000, Sailun Tires, Andersen Aluminum hitch.
Jack350 is offline   Reply With Quote
Old 09-24-2015, 01:07 PM   #5
nomad297's Avatar
This is absolutely correct. I have had to purchase two of them.
Bruce
nomad297 is online now   Reply With Quote
Old 09-24-2015, 03:55 PM   #6
You asked if it could be straightened. If it's not creased, then I sure would take a crack at straightening it. I think you'll be successful enough. Maybe not perfect. If it bent so sharply that it's creased, then I think I would buy a new one.
bruceatlam is offline   Reply With Quote
Old 09-24-2015, 05:21 PM   #7
I think I'll try it. It has a gradual bend in it
Old 10-06-2015, 01:59 AM   #8
Motoring
grotto69's Avatar
How did it go? I just bent my awning arm by ever so slowly driving it up against a tree. Mine seems to be bendable enough to get it back so the alum c lines up and covers the arm mounted to the side if the RV. Its about an inch off right now. Still working on it
grotto69 is offline   Reply With Quote
awning, bent
