Old 06-15-2019, 08:55 PM   #1
Carefree Awning won't retract
Hello I have 2019 Cherokee 264dbh. When trying to retract the Carefree awning nothing happens. Don't even hear the motor doing anything. I've reset everything pulled fuse etc. Is there a manual override? Any tips?
Thanks for the help.
jsward12 is offline   Reply With Quote
Old 06-15-2019, 09:52 PM   #2
Who Dares, Wins
doc73's Avatar
I have a care free on my artic wolf. If you remove the plastic cover over the motors I believe there is a place to use a drill and run each side in a bit at a time.
2015 ChevyHD D-Max
2018 Artic Wolf 315tbh8
doc73 is online now   Reply With Quote
Old 06-15-2019, 09:58 PM   #3
dbledan's Avatar
Yea and look up the replacement part in the forum. It's a car window motor.
dbledan is offline   Reply With Quote
Old 06-16-2019, 03:36 PM   #4
Thanks for the responses. A local dealership has a mobile repair truck. They are coming by tomorrow.
Old 06-17-2019, 12:34 PM   #5
RiderBloke
RiderBloke's Avatar
Try this
Mine had trouble and I blew the motor trying to make it work. The problem may be the switch, as it was with mine. They can be taken apart - search for the forum item that mentions how to do that. I also found the place where the wires from inside joined the wires from outside was poor so I replaced those joiners. Mine seems to be working well but I also bought a replacement switch of a different make to keep on hand.
Retired Intentional Interim Minister
Member of the BMW MOA
Saginaw Valley BMW Riders
RiderBloke is offline   Reply With Quote
Old 06-17-2019, 06:23 PM   #6
Issue resolved, local service guy said the wires had come loose to the motor. He hooked it up tightened everything and the awning is working fine.
awning
