Old 06-16-2015, 08:16 PM   #1
Crooked Awning
I searched earlier but didn't see pictures of what I am experiencing.
Have you seen an awning do this? Looks like it is being puled too tight on one side or not tight enough on the other. Brand new rig, didn't notice this until tonight before putting it away.
Thanks!
2016 Rockwood Sig. Ultra Lite 8312SS Platinum
2016 GMC Sierra 3500
Equal-i-zer 10K WDH
Tadi Brothers 9" Wireless 120 degree Rear Cam
2015 Nights Camped: 4
2016 Nights Camped: 8
hazmat91180 is offline   Reply With Quote
Old 06-16-2015, 08:23 PM   #2
heavynlori's Avatar
Do you have adjustable arms on it??
Looks like one may be adjusted shorter than the other - check for the knobs to tighten each arm...
heavynlori is offline   Reply With Quote
Old 06-16-2015, 08:35 PM   #3
Yup. You need to adjust the arms. The one on the far left is WAY out there.
rana is offline   Reply With Quote
Old 06-16-2015, 08:46 PM   #4
thanks, I'll check it out! I thought I looks for adjustments and I only saw the knobs to tighten it down, but I'll go out and look again.
Equal-i-zer 10K WDH
Old 06-16-2015, 08:58 PM   #5
Brother Les's Avatar
May be bound on one side or the shock arm may be too weak to hold it up.
Brother Les
Old 06-16-2015, 09:13 PM   #6
Looks like the other 3 are in a lowered position.
Old 06-16-2015, 09:16 PM   #7
deartruc's Avatar
In my pdi the dealer said the knobs have to stay loose. (If you need to tilt a side, pull it down and tighten the knob) It appears the only loose one is the one you have that is way up on the rear. Thoughts? Loose or tight?
2017 GMC Yukon
2018 Roo 23 ikss
deartruc is offline   Reply With Quote
Old 06-17-2015, 09:42 AM   #8
arpipeliner's Avatar
Looks like it might be over extended a quarter or half a roll. Could be pulling loose from the first seam. If not its in the arms adjustments as others stated.
arpipeliner is offline   Reply With Quote
Old 06-17-2015, 09:52 AM   #9
TURBS's Avatar
Knobs should remain loose untill deployment, then they should be locked down untill you retract awning for storage.
TURBS
08 duramax tuned n modded
2011 32bhok Sabre
2015 camping "9 nights"
Old 06-17-2015, 10:42 AM   #10
He was half right. Loose until it's extended. Then you want to make your slope and tighten em up. If you don't they'll just flop around with every little gust.
Old 06-17-2015, 10:59 AM   #11
Unless you have poles and they are staked down, once ours is staked down, I leave the knobs loose and nothing moves.
Old 06-17-2015, 11:08 AM   #12
Me too, but I don't think the OP has your brackets yet. It "rides" much smoother if you allow the supports some room to move.
Old 06-17-2015, 09:46 PM   #13
GOT IT! Thanks all, I'll check this all out when I get it back from storage. This was awesome advice.
Equal-i-zer 10K WDH
awning, roo
