11-06-2016, 11:47 AM
Day/night shade broken cord
Brought the trailer home from the seasonal site to clean it up before putting it in storage and found the cord broke on a blind. Anyone have this happen and was able to fix it?
Phil
2017 Ford F-350 Lariat Crew Cab 6.7L Powerstroke
2014 Rockwood Windjammer 3008W
11-06-2016, 11:55 AM
I had cord pull off of spring. If you remove blind. The top will slide apart exposing spring. That spring needs centered with strings run through blind. You will need new string I did not. It's not difacault to do just relax and take your time. I have more issues with the strung holder attached to wall than anything. Sorry no pictures. I'll try next weekend my unit is over in storage.
11-06-2016, 12:18 PM
Here you go.
11-06-2016, 12:24 PM
I used replacement string from the sewing/craft store and a 4" long sewing needle to help thread the string through. Like John said, it isn't hard, just take your time.
2001 Ford F250 7.3l converted to F350 specs
2014 Flagstaff 8528RKWS
2006 model year Border Collie
11-07-2016, 01:29 PM
Go to fixmyblinds.com.
They have all the materials, and video's to fix your problem. I have repaired several different kinds of blinds , using their instructions. They are prompt with their shipping.
11-07-2016, 01:34 PM
They also sell a kit to repair them. The kits is enough to do 5 shades, it comes with instructions. They are not hard to repair just take your time. When my first one broke it was a few days later 2 others broke so you will get good at repairing them
11-07-2016, 01:55 PM
I had this happen to me a few yrs back, I watched a youtube video on it a few times and then i watched it step by step as i did it and it wasn't as bad as i thought it was going to be. Looking at my cords i think ill be doing a few more this winter while we are on down time.
2012 Rockwood Signature Ultra Lite 8312SS riding on Gladiator rubber.
2004 Ford F350 (Black Beauty) CC, SB, 6sp, 6L work horse.
Camped
2016 - 21 nights
2017 - 42 + scheduled....
11-07-2016, 01:58 PM
X2 on the You Tube Video! Walks you through it easily.
11-07-2016, 02:10 PM
I have the same issue with my blinds. One in particular is just
about to break. My question is: the screws which hold the blind taunt.
They seem to pull out easily. Does anyone know of a good fix. A friend
suggested filling the holes with Gorilla Glue but there's about 8 different
varieties so I don't know which one.
11-07-2016, 02:15 PM
You want the type that does not expand, that just create's a hug mess. Just a basic super glue would work or none expanding Gorilla glue
Camped
2016 - 21 nights
11-07-2016, 07:50 PM
If you don't want to continue replacing torn cords, examine the inside of the U-shaped channels when you have the blinds apart. Mine were aluminum and when the holes were drilled through the channel the drilling left big, sharp burs which Winnebago hadn't bothered sanding down. If you have burs and don't get rid of them you'll be replacing the cords again. Of course, then you'll already have some experience doing it! Have fun!
11-07-2016, 07:59 PM
Camping World carries the repair kits for your day/night blinds. We've restrung 2 four string ones with no issues whatsoever. 2people (one "catching" the string - the other is the feeder) makes the job go quicker. The schematic posted above is great - refer to it while stringing and also watch the YouTube video before you start.
11-07-2016, 08:31 PM
Day/night shade repair
These are quite easy to repair. Cord is available on ebay. You should probably buy 25 yards. On Utube there are a number of videos how to restring it and diagrams as to how the cords have to cross to make them work. Just did ours but being a man thought I could Just do it, crying:: Had to go to Utube and on line to get the proper routing . Use a darning needle to thread the cord. Good luck. Put the coffee pot on!
11-07-2016, 09:15 PM
There are many videos on restringing day nite shades on he internet. We repaired one once using branded fishing line matching the previous color. Your not going to brake that line ever again.
11-07-2016, 09:53 PM
We had to do a prior trailer - bought the cord at a blind place in Arizona where we were at the time and they even gave us the little gadget to string with. Found the best was way to place a piece of cardboard on the picnic table & then were able to take blind apart and walk around it as well. No more problems.
11-07-2016, 10:05 PM
Was easier for me to print the diagrams so I had it right in front of me. Having a severe case of CRS even after watching videos.
11-07-2016, 10:19 PM
for Ian: you can take a wooden match or a broken toothpick (you only need a little bit of it) and put it in some wood glue like Tightbond or Elmers and stick it in the hole for the screw. When the glue is dry, put the screw back in. I prefer using the match sticks (the smaller safety matches in the box) to the toothpicks because they are softer, but, sometimes they don't fit the existing hole easily. Also, you don't need much length (maybe a 1/4-1/2 inch) since the paneling is pretty thin.
As for the shades, we have them as well in our Windjammer and have lost 3 of them so far. One was replaced under warranty and I replaced the second one with a "top down/bottom up" cordless shade from Menards this spring. It was on a tall window in the slide out and the 24" shade just fit. Didn't take very long to replace it and it works like a champ. As I recall, it was about $35 or so for the shade. They will trim the width to size, but it fit great out of the box. The third one, I will replace this coming year and I will use a cordless bottom up shade which is available from Home Depot since the window is wide, but, not that tall and Home Depot has a short shade that will fit. Plan to get rid of all the shades with those crazy strings attached to the wall as each one breaks. For mine it wasn't just the string, but the aluminum piece that the string goes through that pulled out. The cordless shades work great and you can't see through them like you can the ones that come with the trailer.
11-07-2016, 11:23 PM
fl564, if you call the blind manufacturer they will send you a repair kit for free. I had one break 2 days after I bought our 8288 after a 5 min call we had a new cord set on its way, free of charge. (Note that our 8288 is a 2011 and we are the 3rd owner so it is not a 1yr warranty or original owner type of thing) The contact number for our blinds was in the owners manual. If you don't have yours or have trouble finding it, let me know and I will pull my paperwork and get it for you.
Hope it helps,
Tom G
2013 Rockwood Freedom2381G
2011 Dodge Ram 3500 Laramie 6.7L
B&W Turnover Ball w/Companion Hitch
11-08-2016, 07:55 AM
I had this problem with two RVs. The sun deteriorates the cords. Was able to repair the blinds with cords bought at a fabric store. Problem is that this will keep happening. Decided to change all these day/night shades with sheer shades. No chords. Here is the link https://www.blinds.com/p/blindscom-f...r-shade/520110 We replaced 9 windows of various sizes for less than $1K US. For Canadian RVers, the link site is https://www.blinds.ca/p/blindsca-zeb...hadings/500977
Marcel & Jenne
Kemptville, ON
2014 Rockwood 8282WS
2015 Ford F150 Eco-Boost
11-09-2016, 07:52 PM
Radioman
Blinds Repair
I have done a few of these in my time as well. Word of caution, don't over tighten the thread on the button knob. Too much tension and they won't work easy. Good Luck!
Radioman
2005 Ram 3500 4X4 Diesel
2013 Silverback
Yuba City, CA. 95993
