Old 06-09-2014, 03:28 PM   #1
Send a message via MSN to redjet
Dometic 9100E Awning Led Lights
Has anyone else had a problem with the LED lights that came on the awning So far, I've had about half of them go out on my 2014 8310SS.
If you've had the problem and replaced them, how are they attached to the awning? Glued - slide-in strip, etc.
Any help appreciated.
redjet is offline   Reply With Quote
Old 06-11-2014, 10:57 PM   #2
9100E LED Lites
Actually the awning is a 9100E series. Hard to believe I'm the only one with the lite problem.
Old 06-11-2014, 11:05 PM   #3
Plain Old Member
I can't relate as I don't have any awning lights. Just curious, are these mounted to the roller tube or the sidewall of the camper? If you don't get any bites in this section, might try posting same thing in the brand specific section. Sometimes better luck that way.
John and Rebecca Dickson
Emma-7 / Little John-5 / Iva-1
Full Timing Again, Rev B
2013 Ford F-350 Lariat CC LB PSD
2015 SOB TT - With OC's Awning Poles (#8)
At least in Heaven, RVs will be perfect, and I won't have to keep fixing them.
BigJohnD is offline   Reply With Quote
Old 06-12-2014, 11:39 PM   #4
Talked to the folks at Dometic today and was told the lites are held on with double sided tape. A replacement kit costs $71 but they'll be replaced under warranty.
If you haven't seen them, they are white, 12v and mounted on the underside of the awning near the camper wall.
Old 06-13-2014, 12:23 PM   #5
Plain Old Member
Ok. Pretty much the one's everybody has. I have seen some mounted to the roller tube, but very few. I still do things the old fashion way. Hang lanterns, lights or whatever on the awning.
Old 06-13-2014, 12:31 PM   #6
White?? Youroo!!
ID:	55117   Click image for larger version
dometic, light, awning, led
