Old 03-18-2019, 08:49 AM   #1
Dometic 9100 arm replacement
I have to replace the arms on my 9100 awning. I have everything I need but the pop rivets for the bottom of the arms. Does anyone know what size rivet (diameter and length) is needed.
Does forest river have a helpline that can give that info?
Thanks for any help.
blasingame is offline   Reply With Quote
Old 03-18-2019, 08:53 AM   #2
bubbles's Avatar
About a week or two ago someone else had issues with the awning and the kit from dometic is 3/16 Oscar rivets. I'm pretty sure this is correct.
Old 03-18-2019, 08:58 AM   #3
bubbles's Avatar
Here's the link
Help! Dometic 9100 Awning Fiberglass Camper Mounting
Old 03-18-2019, 09:13 AM   #4
And within minutes problem is solved.
Thanks Bubbles
Old 03-18-2019, 10:07 AM   #5
007matman's Avatar
Fyi..
The Dometic rivets posted in this thread worked perfectly.
Awning is back on and working perfectly.
Learned my lesson with fleabay though. The brackets sent with my replacement arms were bent. I had to take the arm apart and use my old wall bracket which fortunately wasn't damaged when the arms were destroyed.
It would have been so much easier to just leave the wall bracket on there and replace the mechanism. The only thing that holds it together is a few pins and some of those internal star washers.
Dometic charges over $400 for the set.. what a crock you can't just buy a replacement mechanism.
007matman is online now   Reply With Quote
Old 03-18-2019, 10:32 AM   #6
cavie's Avatar
Originally Posted by 007matman View Post
Fyi..
Amazon is your friend
https://www.amazon.com/s?k=dometic+a...b_sb_ss_sc_8_8
2011 Keystone Sprinter 323BHS
Port Charlotte Fl/Hinsdale Ma
Retired Master Electrician.
Old 03-18-2019, 10:44 AM   #7
007matman's Avatar
Originally Posted by cavie View Post
Yeah.. this is what I had to buy. I got the set (both right and left) for $250.
This is just for the left side.
Dometic Parts 3312487.030B Arm Assembly Kit Lh F/9100 https://www.amazon.com/dp/B07KL1KJ72..._dX7JCb7TJG8SM
They don't sell just the arm pieces for the 9100. All I could find was a complete assembly.
dometic, replacement
