Old 07-08-2012, 07:23 PM   #1
Dometic 9100 power awning.
Hello all. I have a Dometic 9100 power awning that will not operate. When I operate the switch, I can hear the motor trying to work. It appears that the motor wants to work, but something is siezed. I have 3 questions1-has anyone had this problem. 2-can it be lubed. 3-If i remove the end cap, is there a tension spring inside the tube that is going to unravel? I had a manual awning on my last trailer and damn near lost my fingers when I took the end cap off. The trailer and awning is only 2 years old so I find it a little disappointing it failed already.
Scotchmo is offline   Reply With Quote
Old 07-08-2012, 07:38 PM   #2
Sounds like it is bound up by the awning matl being rolled crooked. Put the emergency strap in the roller and have someone try the switch while you pull on the strap. DO NOT remove the cap on the end of the roller on the opposite end of the motor end.
Old 07-09-2012, 09:23 AM   #3
Thanks, but I had the end cap/arm off of the awning tube/motor and it still will not opperate. Any other ideas from anyone?
Old 07-09-2012, 09:29 AM   #4
Might try gently prying the arms away from the trailer at the top. It might take 2 people on ladders to the side of the arms while someone gently bumps the switch.
Might want to make sure the switch is not messed up. When you try to deploy it, does it try to unroll or roll?
Old 07-09-2012, 09:56 AM   #5
Help the awning to unroll when you press your switch to open
SALTY is offline   Reply With Quote
Old 07-09-2012, 10:15 AM   #6
Thanks dunnnc and SALTY. I tried both of those options. Test light shows the switch is working properly. I have manually unrolled it and tried the switch. It will not go either way even with no tension on the awning fabric. I may have to get into the motor but I am concerned there is a "cobra" spring waiting to take my hand off. Any other ideas are more than welcome.
Old 09-13-2012, 12:50 PM   #7
These awnings are awful, we have had two motors replaced in two months on our Silverback, Dometic is no help at all, they have little to offer when we ask why motors are burning out. It would be different if we used it a lot but, we have not. We are going to replace it with a manual one.
hihosilver09 is offline   Reply With Quote
Old 09-13-2012, 04:30 PM   #8
Okay. Here is the long and the short. I contacted Dometic and asked them if there is a tension spring in each end and they said yes and I had better bring it to a Dometic shop. I get that, they want to support their dealers. They lied to me. I took the end out with the motor and there is no spring in the end of my tube. Just the motor. I took the three screws out of one end of the motor and removed what I believe was the brake. Unfortunatly I broke a wire while cleaning the rust up on that part of the unit. I put the assembly back together minus the brake. I reinstalled the rest of the rigging, tried the switch and the awning now works. The only problem is, if i don't completely extend, or completly retract the awning, it will retract all the way on it's own. I have no idea if your awning has springs on either end, but mine didn't.
Old 02-28-2016, 09:45 PM   #9
Great info Scotchmo, I have damaged my awning on the left end tube, and need to replace or possibly repair the end cap cover and bearing or shaft that it rolls on. I also have new fabric to install while I'm there. The 8500 series manual awning videos on you tube DO have wound springs on either end, that need to be carefully unwound to repair the ends. Randy
Old 02-28-2016, 10:10 PM   #10
Facing the awning, the motor is on the rh end and the torsion spring is on the left end. There is NO spring on the motor end.
Old 02-28-2016, 10:36 PM   #11
9100 power awning
So, Hi Old Coot, so if I have damaged the spring end, I should be able to get the HD torsion spring kit for a 20 foot awning, which includes the spring winding that goes inside the tube, and the grey end cap w/the 3 rivet holes and the roller bearing post and bracket to mount to the existing arm. (52.29) available from Pacific RV parts.
Put vise grips on the bracket and unwind until no more tension counting the rotations, drill out the rivets and remove the old assembly. Other side no spring? Just remove the wire or unplug- slide in new awning material from the back end- gotta fix that end anyway, and put it all back together. RIGHT??
Randy
Old 02-28-2016, 10:43 PM   #12
Randy
That is correct, but if you already have tension (torque) on the lh end, the spring must still be good. Just be careful unwinding it just in case it isn't broken.
Old 03-10-2016, 11:44 AM   #13
Can anyone tell me how many turns need to be put on the tension springs when putting it back on the camper? I failed to lock mine when I took it off to replace the awning.
retiredff is offline   Reply With Quote
Old 03-10-2016, 12:22 PM   #14
TURBS's Avatar
http://manuals.heartlandowners.org/m...stallation.pdf
2015 Columbus 320RS
2008 2500HD Duramax
2015 nights camped "34"
Old 03-10-2016, 04:59 PM   #15
Thank you very much. The link is greatly appreciated.
Old 03-10-2016, 05:20 PM   #16
This one might help also. I had 11 turns in mine when against the camper and added 2 more for a total of 13. Less strain on the motor retracting.
File Type: pdf WeatherPro Replacement Manual 3307927.024 - Copy.pdf (1.61 MB, 359 views)
9100, awning, dometic, torsion spring
