Old 10-26-2018, 02:55 PM   #1
Door bowing in the middle where door handle is
When you close my door with out it latching, the top touches the door frame, the bottom touches the door frame, but where the door latch is sticks out between and 1/8 and quarter of an inch from the frame. When I try to close the door from the inside it wont close because of the bowing; the plastic piece your grab to close bends a bit when I close it and get I can't get it to the latch. Closing from the outside is not an issue because
I can put pressure on the door. First, is the normal? Second, I have had the trailer for a little over a year. Will warranty cover the door?
Doug D is offline   Reply With Quote
Old 10-26-2018, 06:56 PM   #2
SeaDog's Avatar
list the model and make of your rig others with the same model may have had this problem and can help you with it.
Retired Navy
Jake my sidekick (yellow Lab)
2016 Flagstaff 26 FKWS
Old 10-26-2018, 07:34 PM   #3
Sorry about that. Grey Wolf 26RR toy hauler.
door
