Old 07-20-2010, 08:01 AM   #11
Herk7769's Avatar
Originally Posted by bob34787 View Post
good luck with that, if you need kevins number at cedar creek let me know. I m not allowed to go back to my dealer, I was labeled as a difficult customer and told never to return.
LOL -
HAM CALLSIGN - KC3FFW
Old 09-28-2010, 04:32 PM   #12
Herk7769's Avatar
OK, I need a part number for that closer. My shock/closer is destroying my door and I am out of warranty.
Any help is appreciated. Lou
Old 09-28-2010, 06:33 PM   #13
Lou, i see you are from PA. I deal with Reicharts Camping Center in Hanover PA. You can call them and maybe they can help you, Here is the phone # 1-800-521-5631. They may be able to give you apart number.
Old 09-28-2010, 06:54 PM   #14
Herk7769's Avatar
Will call them tomorrow. I will let you know what I find out.
Old 02-13-2011, 03:22 PM   #15
Herk7769's Avatar
Update
The closer is still destroying my door. It is now twisted so far out of plumb that the dead bolt does not work. It says it is a 20 PSI closer. Is that the correct part for my door?
Name:	Key West 2011 105.jpg
ID:	4458   Click image for larger version
Name:	Key West 2011 106.jpg
ID:	4459   Click image for larger version
Name:	Key West 2011 110.jpg
ID:	4460   Click image for larger version
Name:	Key West 2011 112.jpg
Old 02-13-2011, 05:07 PM   #16
With some google searching you should be able to find an adjustable lighter duty that will work. Here is one I found in a few minutes poking around that might be adaptable - Wholesale High Quality Door Closer for Cabinet
min qty of 10 sucks but with some more looking you might have some luck.
rick_h is offline   Reply With Quote
Old 02-13-2011, 05:13 PM   #17
Herk7769's Avatar
Thanks for the reply Rick. I think I am going to try and adapt a screen door shock spring and a hold back clip. The piston is a bust IMO.
Old 02-13-2011, 05:44 PM   #18
Lou, i will check with a few of our lock and door hardwear suppliers tomorrow and give them the info on your door closure and see what they come up with.
I don't have one on my camper and i didn't realize it was mounted on the out side. Door closures should be on the inside to where it pulls the door closed, not push it closed and if there is no place to put it on the inside, then i would remove it altogether because of your issue.
Old 02-14-2011, 07:33 AM   #19
Herk7769's Avatar
This is not a closer. It is a "hold opener"
When you unlock the door the piston literally pulls the door from your hand and flings it open and holds the door at 90 degrees to the camper.
You need to overcome the piston to close it.
Old 02-14-2011, 07:54 AM   #20
Ok, i understand, well i guess one has to be careful if some one comes to your door and you open it, they could get hit with the door if it slips out of your hand. That's a safe feature.
Are you looking to find a replacment that does the same thing but with less force or something all together different?
