Old 12-24-2013, 12:03 PM   #1
jonrjen's Avatar
Door lock recall, anyone else have a problem?
Got the trailer a week ago, checked the door key for the recall information and found out I fell within the recall.
Emailed the information for the replacement parts and received them with in 3 days, pretty impressive turn around time considering the holiday mail overload.
I inserted the Blue Took Key and after a few tires I did get the tumbler to pull free on the lower dead bolt.
However, I can't for the life of me get the top paddle tumble to release and pull free.
Any suggestions?
Thanks in advance,
2013 Ford F350 FX4 4x4 PSD
2013 Wildcat 353LS
2015 Day/Nights Camped 5
2014 Day/Nights Camped 29
jonrjen is offline   Reply With Quote
Old 12-24-2013, 12:05 PM   #2
jonrjen's Avatar
Instructions say to have the key slot in the 12 O'clock position, insert the blue key and pull the tumbler out......anyone find that a different position is required to release the tumbler?
2013 Wildcat 353LS
Old 12-24-2013, 12:16 PM   #3
Ford Idaho's Avatar
I just did this awhile back I did have to wiggle the door lock tumbler some but it was not a lot.
have you tried spraying some WD-40 or liquid wrench in it?
Work it left and right full turns with the regular key.
Old 12-24-2013, 01:46 PM   #4
jonrjen's Avatar
I had to run out and pick up a package and when I got back I jumped out of my truck went over to the RV, stuck the blue tool key in the cylinder and it pulled right out. Guess I wasn't biting down on my tongue just right the first dozen times that I tried to remove it.
Sometimes there is just no reason for how things happen, they just do I guess.
2013 Wildcat 353LS
Old 12-24-2013, 02:07 PM   #5
B47
Yep - sometimes you just got to take a break when something isn't going right.
When you come back,everything just falls right into place.
Old 12-24-2013, 02:27 PM   #6
onetonford's Avatar
I just got mine changed about two weeks ago and had the same issue but found if you insert the removal key you have to insert it completely and wait a few seconds jiggle slightly and slowly pull the tumblers out. also I need to quit procrastinating and send the old ones back.
2001 Ford F-350 DRW 7.3
2011 25 RL Wildcat
former fiver 1976 Fourwinds had for 35 years
onetonford is online now   Reply With Quote
Old 12-24-2013, 02:32 PM   #7
Ford Idaho's Avatar
I wondered why they wanted the old ones back, the tool I can understand.
I sent the old ones in a couple of days after I changed them out.
Old 12-24-2013, 07:33 PM   #8
Lloydg's Avatar
Send a message via AIM to Lloydg Send a message via MSN to Lloydg Send a message via Yahoo to Lloydg
Just speculating, but they might want the bad parts back to submit to their supplier for credit. It might be a tax issue too. Either way it's nice they send you the new lock before receipt of the bad lock.
Heartland Big Country 3150RL
2013 Ford SD F250 4x4 SC; 6.2
Reese 18K Elite w/slider - Ada, Michigan
Lloydg is offline   Reply With Quote
Old 01-01-2014, 07:33 PM   #9
Sbryant's Avatar
What exactly are the parameters on this recall? I have. '14 Gtown 360 MH. Is it affected?
Sbryant is offline   Reply With Quote
Old 01-01-2014, 07:37 PM   #10
Lloydg's Avatar
All the information you need is in this link.
http://www-odi.nhtsa.dot.gov/acms/cs...3E039-9876.pdf
door, recall
