Old 07-08-2015, 06:05 PM   #1
Flybob's Avatar
Door Opening not square
The door of my 2015 Freedom Express has always been hard to close ( needed an extra push). This week I decided to see what the issues is. Upon inspection, I noticed that the door frame ( and opening) is not square. In addition the strike plate was put in backward. I switched the strike plate, but the screws in the strike plate still hit the door. It appears that the cutout in the side of the trailer ( it's Asdel) appears to slightly undersized and not square. Short of removing the door frame and trimming the asdel, I do not see an easy fix. Will try to find some thin head screws.
2015 Freedom Express 248RBS
TST Tire Monitors
Honda 2000I + Companion
2 100W solar panels
Old 07-09-2015, 10:30 AM   #2
Dave_Monica's Avatar
Are the screw heads above the strike plate causing inference with the edge of the door. Could you counter-sink the strike plate holes deeper/larger such that the screw heads are flush?
Dave
Old 07-09-2015, 10:54 AM   #3
Flybob's Avatar
That is probably the plan. Currently uses pan head screws. Will try countersinking screw holes in strike plate and using flat head screws. If I can get about 1 mm lower, I should be OK. To complicate the problem, screws are fastened to opening in frame with screw clips which add about 0.5mm . I'm thinking assembler drilled screw holes too big and solved it with screw clips. I think I can get a nut on back of frame ( thru strike plate opening) and eliminate screw clip as well.
TST Tire Monitors
2 100W solar panels
door
