Old 05-06-2017, 03:16 PM   #1
patmac's Avatar
Door rubbing and difficult to open/close
Hello,
This is my first TT and my door is pretty difficult to open and close. I took some pictures to show where it is rubbing. Both the screen and outside doors are hitting the strike plate. Wondering what the best option is?
Is this something that would be addressed under warranty?
Is there a different strike plate I can install that is more flush?
Should I just beat it with a hammer until it clears?
Thanks for the advice!
Pat
Name:	2017-05-06 12.54.08.jpg
ID:	136948   Click image for larger version
Name:	2017-05-06 12.53.30.jpg
ID:	136949   Click image for larger version
Name:	2017-05-06 12.55.02.jpg
patmac is offline   Reply With Quote
Old 05-06-2017, 04:02 PM   #2
M109Rrider's Avatar
Does it do it with your stabilizers down? If so, back off on them a little
Jason and Billie
2018 F-250, 6.2L
2011 Prime Time Crusader 320RLT
M109Rrider is offline   Reply With Quote
Old 05-08-2017, 11:53 PM   #3
patmac's Avatar
That did the trick. Thank you very much!
Old 05-09-2017, 05:45 AM   #4
M109Rrider's Avatar
No problem, we've all been there. Should only be enough weight on the stabs to take SOME of the bounce out.
Jason and Billie
2018 F-250, 6.2L
Old 05-23-2017, 08:15 AM   #5
Super Thirty's Avatar
I have a similar problem and tried taking pressure off the stabs but it didn't change anything. I had to have my doors changed because some little darlings broke into our trailer while in storage. The forward door works fine but the rear door is hitting on the door frame. It wasn't when I picked it up.
Super Thirty is offline   Reply With Quote
door
