Old 05-09-2011, 10:44 PM   #1
Door rubs awning
Hi,
We just brought our windjammer 3006 home tonight and I noticed that when the awning is out, the door rubs on it a bit. Has anyone else had this issue? Not sure im too impressed with it.
2012 Ford F150 Crew Cab 4x4 EcoBoost
2011 Windjammer 3006W
ThePsnaps is offline   Reply With Quote
Old 05-09-2011, 11:04 PM   #2
Coops1's Avatar
You'll need to install an awning door roller to save your awning.
Coops1 is offline   Reply With Quote
Old 05-09-2011, 11:05 PM   #3
Ill look into that. But its brand new... why would it rub like that?
Old 05-09-2011, 11:22 PM   #4
Terier's Avatar
As for the Awning door roller - I need to check and see what this is and if it would work for my trailer.
In the meantime you might try raising the awning a little higher on the door side. I learned to do the "open the door" check when opening up the awning.
Old 05-09-2011, 11:50 PM   #5
flyrotor's Avatar
Originally Posted by ThePsnaps View Post
Hi,
That's pretty common, your awning is mounted at the top of the trailer and the door is pretty close, is your awning an automatic awning or manual?
If it is manual, you can raise the awning a bit higher, not sure about the automatic ones. Also, the door roller works well, either way, there is a solution that will work, not to worry about this one....
flyrotor is offline   Reply With Quote
Old 05-09-2011, 11:56 PM   #6
grhodes50's Avatar
My power awning will rub if I run it all the way out. The manual states to open the awning until the flap hangs straight down. When I do this the door doesn't rub.
Just something you might try.
Gary & Trish
2018 Nights Camped - 5
Old 05-10-2011, 05:13 AM   #7
Ill try that as well. thanks everyone.
Old 05-10-2011, 07:26 AM   #8
KyDan's Avatar
Here's a picture.
Campingworld or just your local hardware store ought to
have something you can use if you're a little bit handy with
a screwdriver!
Welcome to the group!!
Search - awning door roller - Camping World
Peace!
Dan & Rita D
Blue Ox WD hitch
Old 05-10-2011, 09:28 AM   #9
My brand new trailer door rubs too. Its an auto awning. I just retract it an inch or two. That prevents the rubbing.
ewwatson is offline   Reply With Quote
Old 05-10-2011, 09:52 AM   #10
tbritt's Avatar
Hi,
Mine does too, but the awning tube is bowed about two inches, the other tariler had the same awning it never rubed while out all the way, these are designed to be tilted so it will shed water if it touches when it level then it's sure to rub tilted......not right IMO.
2012 GMC 2500 HD
2011 303 RK LaCrosse Luxury Lite
Days camped 2010: 274
2011: 365
2012: 365
tbritt is offline   Reply With Quote
awning
