Old 06-12-2015, 01:16 PM   #11
OldCoot
I just don't like the way they look (I know- picky, picky).
Papa GLS is offline   Reply With Quote
Old 06-12-2015, 01:19 PM   #12
PaPa,release the awning switch just Before total deployment,You will have ample Clearance! I got my eye on you! Youroo!! Don't use a Roller/don't cut the Door off!
Old 06-12-2015, 01:23 PM   #13
Originally Posted by Papa GLS View Post
Thanks much for the replies. It barely touches, but I know it will eventually cause wear. I guess it's a roller.
If you have a square corner on the door, you might try cutting a radius on the very corner.
Old 06-12-2015, 01:31 PM   #14
If he has awning poles, when you snug down the ratchet straps, it will pull the awning out to full deployment.
Old 06-12-2015, 01:36 PM   #15
Youroo
Somebody needs to keep an eye on me; I'll be counting on you.
I think part of my problem is that awning has metal (aluminum) cover when rolled up. But when rolled out it rests on the awning about a foot out from the edge of the TT, putting pressure on awning. Gonna think about it a little more before I go with the dreaded roller.
Thanks again for all the replies
Old 06-12-2015, 02:22 PM   #16
Crockett's Avatar
Originally Posted by Crockett View Post
maybe just loosen awning case and shim bottom slightly...may not take much to clear. or just raise case.
my thoughts were, if the awning were one without side arms, by shimming the bottom of the case outward 1/16", you would prolly raise the extended awning a couple inches...
Crockett is offline   Reply With Quote
Old 06-12-2015, 02:28 PM   #17
Youroo
You were spot on. Rolled awning back in just a very little bit & it gave me about 1 1/2 inches of clearance. No roller & I don't need to cut the door off. I do appreciate all of your suggestions, much thanks.
Old 06-12-2015, 03:44 PM   #18
Youroo
If you have awning poles, you can just lift the tube up a little and then stake it down.
Old 06-12-2015, 03:57 PM   #19
Paradise has arrived!
Paradise115's Avatar
Only stop in the shade! I don't have this problem but am trying to figure out why a manufacturer or dealer would do this?
Southwestern Pennsylvania
Paradise115 is offline   Reply With Quote
Old 06-12-2015, 09:56 PM   #20
Youroo
That's right,I have (Awning Support Poles) that I place then tighten the S it out of the hold down straps! I will lead you in the right direction! Youroo!!
awning, door
