Old 09-23-2016, 08:29 PM   #1
Drawer slide hardware
Has anyone figured out the drawer slides used on a Wildwood? One of my drawers won't stay closed. They have some type of "detent" that engages in the last 1/4 inch of drawer travel to hold it closed. I have one that won't stay closed and I can't tell if it needs replacing or just adjusting.
Cedar Creek Lake, Texas
2017 Wildwood 27 RLSS
2016 Ram 5.7L crewcab, 8 speed transmission
CedarCreekWoody is offline   Reply With Quote
Old 09-23-2016, 08:40 PM   #2
Ford Idaho's Avatar
Is there something like this to hold it closed?
They are adjustable.
Old 09-23-2016, 08:59 PM   #3
Left Coast
I'll post a pic in the morning of the factory installed ones in my Rockwood that are adjustable.....
Old 09-23-2016, 09:23 PM   #4
No. They are side mounted ball bearing slides.
Old 09-24-2016, 06:00 AM   #5
Ford Idaho's Avatar
Ah, the IMG I posted is what holds mine closed.
With luck bob Caldwell will be more help later this am.
Old 09-24-2016, 10:37 AM   #6
Left Coast
Here's what mine hasClick image for larger version
ID:	121124Click image for larger version
Old 09-24-2016, 10:56 AM   #7
Originally Posted by bob caldwell View Post
Same as ours,"Catch/hold adjustment is the small "Set screw" under the nylon white piece on one side and over on the other side! Many 1000s of miles and Drawers "Stay Put"! Youroo!!
Old 09-25-2016, 09:48 AM   #8
Issue resolved:
Problem was in the mounting, not the slides themselves.
The slide supports at the back of the cabinet are attached to a piece of plywood which is then attached to the rear of the cabinet. It was poorly attached, with only one screw on the right side, letting the back of the slides droop. I also noted that when closed the drawer face did not fit flush as the slides were not at 90 degrees as they should be. So I shifted the rear mounting plywood right 1/4 inch and attached it properly. Now the drawer fits squarely and let's the slides fully engage the retaining stop.
I will try to attach photo.
Old 09-25-2016, 09:57 AM   #9
See the plywood that is hanging at an angle? It was improperly attached with only one screw on upper right. I straightened it up, shifted right slightly, then attached with three screws.
Old 09-25-2016, 10:01 AM   #10
Incidently, my slides are different than the ones posted by Bob Caldwell. Mine have no adjustment. The issue with mine was that it was not fully closing which it must do to engage the detents.
slide
