Old 12-12-2013, 07:36 PM   #1
Displaced2's Avatar
Edwin window
As anyone installed this window in their entry ?
Supposedly lift up/ventilated entry window to replace fixed opaque factory.
Displaced2 is offline   Reply With Quote
Old 12-12-2013, 07:45 PM   #2
Ford Idaho's Avatar
Have not.
Link?
Old 12-12-2013, 07:49 PM   #3
Displaced2's Avatar
Easyrvwindows.com
Old 12-12-2013, 08:39 PM   #4
VinceU's Avatar
I have changed the window, available up to stained glass appearance. Check the web more available than just Atwood. Very simple to do, remove 10 screws clean all surfaces and use new glass and glazing putty reinstall. Follow disassembly steps and install the same. 1-2 hour project.
Old 12-12-2013, 08:43 PM   #5
I installed one in my Freelander 3150SS and so far I really like it. It was very easy to install even alone by using duct tape to temporarily hold the outside half on while attaching the inside half. It looks good and the sliding half runs very smoothly. The only downfall is that it is on the other side of the screen door so you have to open the door to open or close the window. At the same time I installed the window I also installed a Starlights SL 1000 motion sensing porch light. The LED porch light is very bright and can be set to come on with motion or manually like the regular light. In my opinion they are a couple of good easy to install additions and don't break the bank doing it.
DSurette is offline   Reply With Quote
Old 12-12-2013, 08:50 PM   #6
Displaced2's Avatar
Thank you all.
Old 12-12-2013, 09:55 PM   #7
Always Learning
I don't have it, but it is on my I want list!
