Old 08-23-2010, 10:25 AM   #1
Electric Awning
I was wondering if anyone could tell me if it is possible to retract an electric awning if you did not have any battery power or electricity?My electric awning seems really slow sometimes when I am retracting it so i was wondering about this...What would I do if it would not retract electricly???
gucci is offline   Reply With Quote
Old 08-23-2010, 11:23 AM   #2
CLASS "A" Senior Member
cfsoistman's Avatar
http://www.dometic.com/5f4bb454-f852...04150276.fodoc
This link takes you to the manual. It contains the info you're looking for.
2007 Georgetown 370TS
aka - RAYNMKR
Driver: Charlie
Navigator: Sheri
cfsoistman is online now   Reply With Quote
Old 08-23-2010, 03:49 PM   #3
Thank you so much for this info....I even went to the Dealer where I purchased my travel trailer with this question and they could not answer it for me...Although I did not get one of those pull straps,which the manual said was provided.I will have to try and get one somewhere!!!!
Old 08-23-2010, 04:09 PM   #4
MrT
MrT's Avatar
Wow, that's so much easier than the instructions given in the Dometic/AE manual supplied with my unit. Those instructions actually suggest that you make up a matching power pigtail, and power the awning closed using an auxiliary 12v power source.
2017 Cedar Creek 38CK Hathaway Edition
2015 Ford F-350 6.7 CC 4x4
B&W RVK3300
Full-timing since 5/2/2016. Roam Sweet Home.
FROG Int'l Rallies: 2012-2017
MrT is offline   Reply With Quote
Old 08-23-2010, 04:39 PM   #5
Thanks for asking. I wanted to know ,too.
dick773434 is offline   Reply With Quote
Old 08-23-2010, 05:08 PM   #6
bsmall's Avatar
Great question, and very good answer.
Bill
2008 GMC Duramx-2500HD 4x4 CrewCab
52 Gallon Titan Fuel Tank
Reese18K Signature Series 5th Wheel Hitch With Slider #30085
2010 Wildcat 28RKBS (West Coast Model)
bsmall is offline   Reply With Quote
Old 08-23-2010, 06:06 PM   #7
Herk7769's Avatar
Sigh...
Pull strap provided? Not.
I guess I should have a cord of the correct length made up.
HAM CALLSIGN - KC3FFW
Old 08-23-2010, 06:16 PM   #8
If your awning is rolling up slowly, you can adjust it by taking it out of the arm and putting more preload on the roller. Mine only has one bolt on each end holding it in. You definetly need 2 people when you're doing it, at least I didn't have enough hands. and it's easier to do if the awning is part way open. If you don't have it at the right spot when you pop it out, it's going to release all of the tension when you pop it out.
MightyMike is offline   Reply With Quote
Old 08-23-2010, 08:55 PM   #9
thanks that was great info. I have another question, does anyone know how to get a power awning to roll up evenly? Mine rolls up tight on the front but the rear does not roll up as tight, there is a gap between the TT and the awning.
Thanks in advance
Ray
'04 Dodge 3500
'11 Flagstaff 8528RLWS, Hijacker 16k slider
HTR member Nights camped 2010 -115, 2011 -40 , 2012 -41, 2013 -86,
seatosea is offline   Reply With Quote
Old 08-24-2010, 11:10 AM   #10
So Mightymike are you talking about taking the big roller that the awning rolls up on out?Would anyone have any info on how to do this?This sounds like a risky operation...Also my awning has a lot of wrinkles or ripples in it after it is rolled up...Is there anyway to fix this?I already had my awning replaced last year because of this but it is preety much the same again now..Guess it is something I am going to have to live with...
awning
