Old 01-10-2017, 12:00 PM   #1
Entry door gas strut
I have a 2015 Georgetown that has a gas strut on the bottom of the entry door which pulls the door open. If not held, the door forcefully opens and will slam against the awning, if open, or the awning mounts. I find this extremely unwanted. Once the door is open, it does limit the door from opening further which IS wanted. Does anyone else know of a strut or limiter that will limit the travel but NOT assist with opening? I'm going to be forced to remove it to prevent the door from slamming open. All help and/or input is appreciated.
dksnla is offline   Reply With Quote
Old 01-25-2017, 02:13 PM   #2
gas shock
I have the same problem on my 2017 Pursuit. I took it off. The door will not open or close correctly now because of it. Still trying to come up with a solution.
kingjim01 is offline   Reply With Quote
Old 03-02-2017, 02:29 PM   #3
Strut removed
I finally removed the strut which solved one issue but led to another, that being the door now fully opens. I do have control of the door opening, just not too wide. now my fix is to secure the door open to the wheel preventing it from moving. Not the fix I wanted and may go back to the strut. Oh well
Old 03-07-2017, 10:01 PM   #4
You may be able to move one of the mounts slightly to limit how far the door opens.
2012 Palomino Ultralite T245
2004 F250 Supercab 5.4L
09 Grizzly 700 EPS
09grizzly1 is offline   Reply With Quote
Old 03-08-2017, 12:52 AM   #5
https://www.amazon.com/dp/B000XBGMY4...ing=UTF8&psc=1
These have an internal cable that prevents over extension and will hold the door open.
I uses a smaller version to keep my cabinet doors open.
One More Time Around: Quit Using Your Head
jeffnick is offline   Reply With Quote
Old 03-08-2017, 05:54 AM   #6
World Wide Wanderer
wahoonc's Avatar
Where would you install that for an main door? Seems the screen would get in the way?
Aaron
Aaron & Rhonda
wahoonc & Airangel60
2016 Coachmen Concord 300DS
2015 Fusion Hybrid following along
wahoonc is offline   Reply With Quote
door, gas
