Old 07-29-2016, 01:49 PM   #11
Vince and Charlette's Avatar
I got locked out of my 2015 GT for the same reason. Had to climb in through drivers side window. There is a safety recall on some models of these door handles. Ours was replaced for free. Check with manufacturers web site. The affected models are listed there.
2015 GT 364TSF
Vince and Charlette is offline   Reply With Quote
Old 07-29-2016, 03:07 PM   #12
I called Trimark and there is no recall on the 060-1650 (aka RV Designer T507) door lockset. However, googling the door lock did show that an lot of other people have had the latch bolt fail in the same way mine did. For now, I'll just order a replacement and hope for the best.
mrmilo is offline   Reply With Quote
Old 07-29-2016, 03:29 PM   #13
Originally Posted by mrmilo View Post
Bingo. The latch bolt itself was broken inside so the door handle could not retract the latch. It will need to be replaced but I can still lock the door with the deadbolt. Thanks all for the replies.
How did you get the door open?
fobagbob is online now   Reply With Quote
Old 07-29-2016, 05:32 PM   #14
I unscrewed the lock from the inside. The only issue was that one screw was obscured by the side of the screen door but it was close enough to the edge that it could be removed. It left scrapes on the screen door, but only minimally. Then used needle nose pliers to pull the latch bolt back and the door opened. Until I replace it, the door won't stay closed unless you use the deadbolt to keep it shut. But it does open and you can lock it so it's not too big of a problem.
Old 07-29-2016, 06:03 PM   #15
Thanks for the info, now I know how to remove the latch if this happens to me.
door, forester
